I agree with the above response. I had a JetCat connector / wire that would only show "garbage" on the GSU if you moved the connector very quickly. Once the connector was replaced, no more GSU problem....
Try another cable in both ports on the gsu. If that doesnt work plug the gsu directly into the ecu and eliminate the light board, if that doesnt work then i would suspect your gsu has a bad connection somewhere inside it.
Vin...
