g62 vibration after electronic conversion?
MN
If you convert a g62 to electronic ignition, you remove the flywheel.
Isn't the flywheel part of the balancing of the engine?
Then how can it in balance without the flywheel?
Seems like it would have vibration issues.
My Feedback: (98)
RE: g62 vibration after electronic conversion?
FWIW I've run lots of MT62s, which are clones of the G-62, they have Electronic ignitions and have no issue with excessive vibrations.
NC
All single cylinder engines are going to vibrate, especially the G-62, it hammers the crap out of an airframe, my warbirds prove that. The key is a properly balanced propeller. Remember, all Zenoahs are industrial engines meant to be run in weedeaters and chainsaws.
Which means that the engine must vibrate as little as possible in order to allow the operator to work with the engine all day, day in and day out.
WY
All singles vibrate its the law. An engine designer can chose where the engine vibrates. The G-62 has 2 nodes one about 18-1900 rpm and a smaller one around 33-3600 rpm.
Smooth at higher settings
My Feedback: (54)
ORIGINAL: tkg
Good info. So Pe's 1100 RPM idle must be pretty smooth?
ORIGINAL: tkg
what do you mean by nodes? rpm bands where vibration increases?
My Feedback: (21)
ORIGINAL: STUKA BARRY
ORIGINAL: MetallicaJunkie
ORIGINAL: tkg
If mounted on a flimsy airframe, and equipped with a small propeller, the vibrations will be much worse.
It does however have a vibration "node" at mid rpm, where the wing struts suddenly appears twice as thick... :-) I have never measured the rpm at that spot, but it could easily be the one Pe predicts to be at around 3600 rpm.
My 62 is very smooth.....having heard all these stories I was expecting a paint shaker when I mounted it to my Giant Aeromaster. I admit the Aeromaster has lots of area to dissipate the vibes, but the engine is smooth as silk! Make sure you take time to balance both the prop tips and hub-tuned correctly all will be well.
To eliminate the harmonic vibration in a single would require adding about 6 pounds to the bottom end of 50 to 60cc engine. There is no escaping this with a single. Even a twin has a harmonic and the way to eliminate that is to add a half stroke, half displacement piston and cylinder oriented 90* to the primary cylinders centerline.
