duel elevator servos
My Feedback: (29)
This will work for dual elevator servos. never use a Y, you will never get them to track the same.
You can use a free mix to set up the twin elevator servos, or any other two-servo combination by simply doing a pmix of the primary channel to the secondary channel at 100% with trim on and link on, offset off and switch assignment NULL so that the mix is always active. Here is an example of mixing 2 to 7:
A. Standard mix from 2 to 7 to work twin elevators:
[TABLE]
[TR]
[TD]___[/TD]
[TD]Press Mode (twice if needed) to open Advanced Menu[/TD]
[/TR]
[TR]
[TD]___[/TD]
[TD]Dial up or down to a free Programmable Mix and press Dial to select[/TD]
[/TR]
[TR]
[TD]___[/TD]
[TD]Cursor Down twice and turn dial LEFT to activate mix[/TD]
[/TR]
[TR]
[TD]___[/TD]
[TD]Cursor Down and turn Dial to select channel 2 (elevator)[/TD]
[/TR]
[TR]
[TD]___[/TD]
[TD]Cursor Down and turn Dial to select channel 7 (Aux1)[/TD]
[/TR]
[TR]
[TD]___[/TD]
[TD]Cursor Down and turn Dial left to turn Link ON[/TD]
[/TR]
[TR]
[TD]___[/TD]
[TD]Cursor Down and turn Dial left to turn Trim ON[/TD]
[/TR]
[TR]
[TD]___[/TD]
[TD]Cursor Down twice and confirm switch position is NULL[/TD]
[/TR]
[TR]
[TD]___[/TD]
[TD]Cursor Down, pull positive elevator, and turn Dial Left to -100%[/TD]
[/TR]
[TR]
[TD]___[/TD]
[TD]Push negative elevator, and turn Dial Left to -100%[/TD]
[/TR]
[TR]
[TD]___[/TD]
[TD]Press End twice to close Menu[/TD]
[/TR]
[/TABLE]
B. Turn off default control of channel 7 in Aux-Ch screen so VRC does not affect the second elevator servo.
[TABLE]
[TR]
[TD]___[/TD]
[TD]Press Mode Button (twice if needed) to open Basic menu[/TD]
[/TR]
[TR]
[TD]___[/TD]
[TD]Turn Dial up or down and Press to select Aux Ch[/TD]
[/TR]
[TR]
[TD]___[/TD]
[TD]Press Cursor Twice and then turn Dial left until reads CH7 NULL[/TD]
[/TR]
[TR]
[TD]___[/TD]
[/TR]
[/TABLE]
[TABLE]
[TR]
[TD]___[/TD]
[/TR]
[TR]
[TD]___[/TD]
[/TR]
[TR]
[TD]___[/TD]
[/TR]
[TR]
[TD]___[/TD]
[/TR]
[TR]
[TD]___[/TD]
[/TR]
[TR]
[TD]___[/TD]
[/TR]
[TR]
[TD]___[/TD]
[/TR]
[TR]
[TD]___[/TD]
[/TR]
[TR]
[TD]___[/TD]
[/TR]
[TR]
[TD]___[/TD]
[/TR]
[TR]
[TD]___[/TD]
[/TR]
[/TABLE]
[TABLE]
[TR]
[TD]___[/TD]
[/TR]
[TR]
[TD]___[/TD]
[/TR]
[TR]
[TD]___[/TD]
[/TR]
[TR]
[TD]___[/TD]
[/TR]
[/TABLE]
