RC CAR (YEAH RACING ECS AND MOTOR) works for 5 seconds and slow
Hi all i have an On road RC which i bought of online as used, it was supposed to be working the issue is that it works for the first 5 seconds then stops and there is a red flashing light on the ECS
it is also very slow slower than my 1990's RC car .. the specs are as below
Brushless Year racing motor
Year Racing ECS 35A-SL
i just want it to get up and running..
please help..
please help..
Hi thanks for the reply everyone..
Ok i have an update..
I forgot to say what batteries im using im using 7.2 V NIMH battery packs.. I have found out something..
I charged the batteries 100% and the rc car works
but only for 1 min or so then it goes back to slow and then drives then stops then drives then stops
But the first minute it drives so quick. just like i want it.
Some people said something about low voltage ,. what is that does it mean im getting out of battery?
Hi all
thanks for the reply everyone.. its a YEAH RACING not a year racing it was a keyboard error
I forgot to say what batteries im using im using 7.2V 3800MAH NIMH battery packs.. I have found out something..
Also i have a video and a photo of the car if you need of what it does.
but when i lift it of the floor and throttle it doesn't do that stop and go stop and go.
https://www.youtube.com/watch?v=p9NB03hpuQo&feature=youtu.be
Ive listed the link of the video here it is again https://www.youtube.com/watch?v=p9NB...ature=youtu.be
So il start all over again if you done know the story from the beginning
I have bought a used RC car it runs
Issues as below
I charge the battery full put it in the car it works all sweet for 1 minute or 2 max then after that it starts stopping and going stopping and going as shown in the vid
but when i lift it of the floor and press full throttle it doesnt stop and go?
What is the issue here?
thanks all..
Issues as below
thanks all..
Hi all.
I dont want to buy a new car..
I just want to sort this out
I think where im stuck at is the Low voltage cut off. i need to disable it.. HOW DO I DO THAT PLEASE![Smile](images/smilies/smile.gif)
Please guide me step by step
The car works front back and stops no issues
But i need to know how to get it to stay running..
(ALSO PLEASE TELL ME ALL THE EXPERTS OUT THERE)
will my car get ruined if i disable the LVD the low voltage cut off. I NEVER USE anything else than 7.2V NIMH battery packs.. Please help
I wasn't suggesting buying a new car, just some cheap new electrics.. however there should be a reset button on your esc that should set the esc back to basic settings.. have you tried that?
Sweet how will i DISABLE the low voltage Cutoff from my Yeah Racing ECS 35A-SL
which is the exact same as the (Hobbywing ezrun 35a ESC.) i need a step by step guide,, there is no reset button.. there is a set button which is to set up the car . but there is no reset button
Ok someone advised me to do the following
__________________________________________________ _________
1st off to connect the programming card you need to unplug the ESC from the receiver
plug the ESC's plug into the right hand side spot on top of the card (well at least on mine which is a V2) The symbols where you plug it in should be a circle with a -, a circle with a +, and the final one should look like a squared off capital U (its actually the symbol for square wave, but thats not important here) The black wire on the plug coming off the ESC should goto the -, and the white to the square U symbol.
Once that is done turn the ESC on
(again these are for the V2)
Press the item button till the item # says 3
then press the value button till value says 1
after that press the OK button
then turn the ESC off, reconnect it to the receiver
I did it all and it still didnt work check what the video i made for you guys to watch and hopefully help
https://www.youtube.com/watch?v=kiiS...ature=youtu.be
PLEASE HELP;
PLEASE HELP;
Please help me as i want it going ![Smile](images/smilies/smile.gif)
