H9 Cap & MVVS 1.60 Gasser: Second Impression - Wow! Things are really looking up.
My Feedback: (14)
OK
Kenair, I have been having good luch with a APC 17x8 at around 7800 rpm. I only put 1 gallon through it. I ended up destroying my plane on Saturday and I just sold the MVVS to a buddy.
Good plugs for the engine are:
Champion DJ7J (hot) DJ6J (cold)
The end connector plug has to be sawn off flush with the flange, like the brisk.
If you cannot obtain them, I have them in stock.
My Feedback: (10)
no unlimted vertical but I can do a vertical climb to about 400'
June 24,
I am still pleased with the engine, the Sig Cap is a bit too much airframe for the motor, it is turning 8200 to 8400 on a Bolly 16x10.
If I was a newbie it would seem adequate but I find myself flying at 3/4 to full throttle most of the time. A ten to twelve pound airframe, would be better rather thatn my 13.5 pound CAP.
I picked up a 72" IMP spitfire kit that I will put one of my MVVS 1,6 into.
--ken
June 24,
--ken
My Feedback: (8)
MVVS 1.60
I have a world models 1/4 scale clipped wing cub with a MVVS 1.6 gassser on. Had been running a APC 18x8 prop, flew good, a little faster than a cub should, LoL. Had a 3 blade 16x10 just begging to be used, figured what the heck lets see how this puppy pulls a 3 blade, WOW what a difference.
I had always heard these MVVS like to be loaded down, and she does, matter of fact some say a 16x10 is minimum prop for this llittle beast. Remember these are gasoline engines, not glow the RPM's probably should not be in the 8K and up range. I had one die running in the upper 8's, LoL.
Before I could just barely eeek out a loop, with the 3 blade I can pull 3 loops continuously. Its a blast to see the ole cub perform with this prop.
If ya want better performance from your MVVS try playing with 3 blade props and see what ya can do with your scenario.
#31
My Feedback: (10)
July 16, 2003
Flew with an APC 17x8 on the MVVS red head, taching at 8500rpm on the ground and running 40:1 Pennzoil, have about 1.5 gallon through the engine. I expect another 300 to 400 rpm when I switch to Amsoil 50:1
http://www.sportrc.com/smallgassers.html
#33
Visioneer one,
I am interested in how this engine performs on your stick 120.. I have one stick with a os 160 fx. I have another I am planning to enter into the gas world with. I like the MVVS 160 red head. Please let me know what the results are of your setup.
thanks,
Richard,
[email protected]
thanks,
Richard,
[email protected]
#34
My Feedback: (14)
Who sells the red head in the U.S.?
How much does it weigh and what are the dimensions?
What rpm does this engine spin a 16X8 APC? Is it more than 9000 like the RCS 140?
My Feedback: (7)
NC
www.morrishobbies.com sells the mvvs red head. a 16x8 is not enough prop for that motor. I was spinning an 18x6 pro zinger at 7750 right out of the box, I am sure it would spin a 16x8 as fast as a rcs but it would definitely out perform the rcs with the bigger props. With the motor ignition and the muffler it was 44.5 oz not too bad at all.
#36
#37
My Feedback: (14)
The only problem I see with the Mvvs 160 is the carb is very close to the prop and fitting it into a cowl could be tough. Does anyone know the dimensions from the centerline of the crank to the top of the spark plug cap?
Brian
Brian
#38
NC,
Brian
Brian
#40
My Feedback: (10)
I do not think I can burn an ounce a minute, maybe .75 ounce at full throttle, I'm using a 12oz tank in the Laser 200.
I put a 1/4 to 3/8" thick spacer on the prop hub to push the spinner back plate out a bit from the carb, the threaded protion of the crank is quite long and can accomodate a spacer.
Height from c.l. to top of head is ~ 3.875" plus the spark plug cap, hard measuring as the engines are cowled in.
I flew the Cap 232 with the red head with a Menz S 17x8, rpms at 7700.
Last week I test flew the 1/4 Lanier Laser 200 with my older MVVS 1.6, all up weight 11.6 pounds, flew very nice, lands like a ***** cat,
I used the stock black steel muffler in the Laser 200, plugged up the horizontal outlet and brazed in two 1/2"0d pipes in the bottom, works quite well.
my flying buddy just ordered a new 1.6 red head to replace the OS 120-4C in his laser 200. Mine has the blue trim.
more info at
more info at
