Whats the Difference Saito 1.20 , and the 1.50 ?
When I try to find the weight of the two engines I get different amounts. Horizon Hobbies tells me there's a 2 oz difference between the 120 and the 150, the 150 weighing heavier! On the Saito webcite, it has the 120 weighing heavier than the 150 ? It also only shows the 150 engine being 1mm taller than the 120. I need to know the weights of both engines with mufflers included. If the 150 is lighter, I'll probably go with that one. If not, the 120 is the ticket.
How much different RPM gain with the same given prop can one expect with the 150 over the 120?
Dennis
Dennis
My Feedback: (102)
RE: Whats the Difference Saito 1.20 , and the 1.50 ?
D, I have a 10 or 11 year old 150 that has higher compression than the one they make now, it turns an 18x6 ProZnger at just under 9,000, 8,950 or so on 15% WildCat Premium Extra. I believe the 120 will do similar with a 16x6 but I don't have one.
