Carden 40% Cap + tuned cans?
My Feedback: (69)
AR
Does anyone know which cans and headers will fit a 3W 150 in a carden 40% cap? There is a tunnel in the bottom of the plane, but the regular 3W/PEFA cans and headers are too long.
My Feedback: (31)
RE: Carden 40% Cap + tuned cans?
I know where you coming from. I thought of installing cans in one my Carden Caps. If I recall the only thing I found that appeared to fit the requirements was from KS or Krumscheid. You'll have to look into the required header length for these cannisters.
http://www.moki.co.uk/krumscheid.html
http://www.krumscheid-metallwaren.de...-englisch.html
http://pefa-modelltechnik.de./
No, but I can provide you with a picture of my new MTW's next to my old Pefa's if you would like a size comparison. They require an 11-11.5" header.
-Kelly
-Kelly
Here is a picture of the Metall Technik Weiershäuser canister (bottom) compared to the Pefa (top of course). The MTW seems to be noticably lighter, smaller in diameter, but longer. The MTW also will keep the stock power of stock mufflers if not add a few hundred RPM. The Pefa's will generally knock off 200 rpm but are usually the quietest cans out there.
-Kelly
-Kelly
Michael, email Ivan Kristensen and ask how he mounted his cans in his Cap that he flew at the Master's. He ran the Pefa's, if you are going to run a 3W they really like the Pefa's. His email address is [email protected].
-Kelly
-Kelly
Been there, done it. It's not hard to mount the pefas into the cap. They're just short enough to fit fine without any modifications to the headers other then some slight bends to get them lined up. Got the same rpms as standard mufflers. They're the only cans that will fit that I know of.
