New Evolution 20cc gas engine
I just purchased one of the new Evolution 20cc gas engines. Does anyone out there have any experience with this engine as yet? I plan to install the engine in an Great Planes Stuka.
Best wishes and good safe flying.
Heli-NuBee (AKA Roger the radial rabbit)
RE: New Evolution 20cc gas engine
http://www.rcuniverse.com/forum/m_11468068/tm.htm
Good place to start, I've bought the 10GX and 15GX... not the 20... yet<br type="_moz"/>
My Evolution 20GX gas engine powered GP Stuka is almost complete. I am looking forward to the engine break-in and maiden flight.
I completed the odds and ends on the GP Stuka today and the plane is ready for the first engine break-in run. I plan to run the Evolution 20GX gas engine tomorrow.
I performed the ground break-in run yesterday on the Evolution 20GX gas engine powered Great Planes Stuka. A short clip from the break-in run is shown in the video below. Sorry for the poor quality but I had to shoot the video alone with a cell phone.
http://www.youtube.com/watch?v=0Exj5DvbuF0
Heli- NuBee (AKA Roger the radial rabbit)
I had the maiden flight of my Evolution 20GX gas engine powered Great Planes Stuka today. I had two good flights and things went very well. The plane flies quite well and the engine perfomed perfectly. The engine has plenty of power and most of the flights were at about half throttle. So far, I am very impressed with the engine. Sorry but, no video, I just have not been able to find someone locally that can video a flight without all blue sky and sound only.
My Feedback: (22)
AB, CANADA
hello,
i have a great planes j3 cub 90" wing span about 12LBs ON Floats what would be the better suited and fit out of the two engines the 15cc or 20cc evolution it curently has an o.s .91 surpass 4 stroke thanks for you input
My Feedback: (27)
PA
I have an Evolution 20cc on a hangar 9 P-47 60 size. Engine runs fine but has a severe lack of power. Tried to run a Biela 14-8 4 blade prop which looked awesome. Would only turn 4800 rpm. Anything larger than 15-6 will not spool up at all. Anyone else have a power problem ?
IL
Hi opspro,
Was the 15x6 you tried to run a 2-blade or was it a 3- or 4-blade? A 14x8 4-blade is a heavy prop, but I would think it should turn it either way.
Out of curiosity, when did you purchase the engine?
Jimmy
Jimmy
this motor is way underpowered!!!!!!! no hi rpms....tech assitance at horizon never returned call...carb was faulty out of box..was sent new one...have 6 tanks of fuel thru it with a 15 x 7 prop...this motor is terrible!!! i have a thunder tiger pro 46 that has more power than thi motor.do not buy this motor i only had for 3 weeks now.$274.00 what a waist!!!pulling it off and in the recycle bin it goes!!!p.s. will not buy from horizon
My Phoenix Ryan STA is almost ready for its maiden flights now. Phoenix Ryan STA, Evolution 20 CC Gas engine, J-Tec muffler (note: the stock pitts style muffler that comes with the engine would not fit this plane), 16 oz tank, 15x8 prop, weighs in at 9-1/2 lbs full of fuel.
