G-38 spring starter
My Feedback: (27)
ID
Been about two years so my memory may be a little fuzzy......just remove one of the cap screws holding the mount and engine together put the center on the shaft, its tapered to grab the crank , place the spring where it will fit down on the center pirce in the slot and bolt the spring to the crankcase where the U-bend fits around the bolt.
It's very easy and reall can go one way....works well!
