Power system sport plus set-up
My Feedback: (13)
MN
Hello
After I found this forum and started reading the threads it became apparent at least to me the boys were having trouble interpolating the written instructions written I'm guessing by an engineer. Have you ever made available a more direct approach to setting up a PS with a step by step guide or even a schematic detailing exactly what goes where. Sure would help me and I'm betting I wouldn't be alone. Anyway maybe something to consider
I just received a PS Sport plus with optical cut-off and fail safe switch for my AW 85CC Extra 260 with 5 X HS7955TG and 1 X 5985 2 X Fromeco 2600 for system power and one 2600 on ignition. What I forgot on my initial order was which Smart-Fly regulator do you recommend for the ignition
Most pilots in large scale at my field fly your equipment and now so will I beginning with my first biggin'
Thank you
Dave P
Thank you
Dave P
AZ
RE: Power system sport plus set-up
Hi Dave,
Yes, the instructions were written by an engineer, me. The problem with schematics diagrams is there are so many ways to hook things up its hard to cover all the bases. I feel its easier to instruct the user on what function everything performs so they can understand the unit's function and use for their application appropriately. Also, this is why we are on a number of support forums, to help users get past anything that is not clear to them.
Well I am with dmparri on the schematic. I have my first Smart-Fly products (Powerexpander Competition 12 & ignition cutoff) on there way and like it or not first time user need more help than the standard user's guide. A schematic gives you that warm fuzzy that you have connected things the way the manufacture intended. Another thing is charging through the board dose not talk about how this is handled since our A123 / LiPo battery also have a balance tap to consider. Please help the newbie!
AZ
For the most part people call for tech support on the things they do no understand. I can usually walk then through things in about 5 minutes. There are so many ways to hook these units up it would be nearly impossible to cover them all in a manual with schematics. As far as charging with the card and battery packs that need balancing, its really not possible. The only thing I can
suggest is to take your balance plug to a charge jack on the side of the plane (like an Ernst charge jack if its a JR style) and then charge through the card for the main charging a use the balance plug on the side of the plane to connect your charger balance. Most of the time the balance plug is not a JR style. If it is a JR style, there are two ways to wire them so that confuses things. Also, connection to the board is a two conductor Deans so there is no way to connect the center tap.
AZ
If you have more questions, you can call or post again. The problem with batteries that need to be balanced is many. First, there are numerous types of balance plugs. Second, the chargers all charge differently, some charge through the main power connector and balance using the balance plug. Other chargers charge through the balance plug only. Also, since out units only need power and ground then there is no where for the balance lead. All the high current plugs have only two contacts. This is a thorny issue for which there is no good solution.
My Feedback: (23)
GA
Yes, there are lots of people that find the instructions confusing. The little lady on the web page made it look so easy, and for what she was demonstrating worked. So why would it be so hard to put instructions on a DVD or CD that explains every aspect of each adjustment and what to expect. I still cant get all functions to work as explained in your instructions. I be-leave you could sell a lot more
equipment if there were better instructions. I had better luck trial and error method.
AZ
I am sorry you had problems with the instructions. I have about 50% that are fine with them and 50% which find them hard to follow. I hope to have something better for the new products as they come out and go back to some of the older products and see how I can improve the instructions. Thanks for your input and I will see how I can improve.
