KingTech Turbines International Barry is your host and will help you with all your Kingtech questions and concerns.
K80G max rpm problem
Old 10-19-2015, 09:48 AM
INDIZA
Default K80G max rpm problem
I have bought a k80g with 120min and the ecu max rpm is set to 144000rpm and I cannot set it higher to 145000rpm, only lower, is there a reason for this as my other K80 all go to 145000rpm?
Old 10-06-2016, 11:43 AM
h.hibbler
My Feedback: (24)
Did you ever resolve your RPM issue? I am having the same problem with a K 80G that will only go up to 141 Max RPM setting in the ECU. The engine is only a year and a half old just purchased used. I have a new K 80G purchased in May of this year, that does go up to 145K setting in the ECU.
I Called Barry this morning and he told me he would not program the ECU to reach 145K because of safety issues. Barry also told me K 80's are 80N class turbines which equates to only 17.89lb of thrust which is just shy of 18lbs.
The specifications clearly state Thrust: 8618 g @ 21.1° C. (19 lb. @ 70° F. )
Is Kingtech representing K80 series engines as 19 lb thrust engines, when they are really 17 lb thrust engines? If this is the case we have a serious problem with them not being truly honest or sincere by providing consumers with false information. It clearly states in the owners manual and the Kingtech website the K 80 as a 19 lb thrust engine.
Old 10-17-2016, 09:37 AM
INDIZA
Still only 144000rpm can not change this, this is my fourth k80 and the only one only going to 144000rpm.
