feda stability
OK
feda stability
With some help from my local hobby shop,I was able to improve the feda's hovering stability. I first installed a longer flybar,on this flybar I installed a wheel collar to each side for added weight. Next I installed a large thin plastic washer on the cyclic control of the transmitter.
These things really helped,I put the plastic washer on last because the response was better,so I thought a cyclic limiter would help,it did.
