Pst 600r
Pst 600r
Not entirely new to Rcuniverse, but forgot my old username. So, nice to be back!
I am, however, new to jets, but hopefully learning quickly.
I have a PST 600R that the TEMS died on. I have since replaced it with the Xicoy FADEC, and set it up as suggested by someone in the know on this forum.
I have now run the turbine which starts and runs without fault, almost....
I'm, manualy supplying tbe gas at start up and so, I have been removing the gas line while the engine is running. When I remove the gas line, there is a constant stream of vapour coming from the gas line, which increases with revs. There are actually a few drips of fuel coming out of the gas line too.
I know this is not normal, but why is it so???
Thanks.
Thanks.
Thanks NZjet. The only other turbine I've run is a Kingtech 80E. I don't plug the gas line on that after start up, and haven't noticed it venting fuel or vapors, but now I know, I'll plug!
Cheers!
Cheers!
