New Product Alert! Advance Radio I-Charge and I-Charge Turbine
New product out now.
The I-Charge from Advance Radio has been redesigned.
Same size and weight, but faster charging and more efficient.
It can now charge both 2s LiFe, Li-ion and Lipo as well as 3S LiFE for ECUs.
Pretty impressive for a charger that fits in the palm of your hand.
Comes in 3 new types
Pocket Charge:
Lighter, easier to use, charges 2 batteries. Great for mounting in your planes or keeping it in your transmitter case to charge at home or at the field.
I-Charge:
Bright OLED screen gives battery voltage, mAhs charged and charge current, charges 3 batteries, simply plug it into a 12v supply and it will start charging. Weights about the same a servo
I-Charge Turbine:
Designed to charge both 2S and 3S chemistries, perfect field companion for your turbine models, no need to worry about excess wires or bulky charges. Simply plug and go with this micro charger.
Check it out and let us know your thoughts
Booma RC Advanced Radio Control Specialists. Battery Chargers
(3 min 1 sec)
(5 min 21 sec)
Pocket Charge:
I-Charge:
I-Charge Turbine:
