Powerbox Systems Professional
My Feedback: (8)
Brand New, FREE SHIPPING, Paypal payment.
For more info send a PM or email to [email protected]
FEATURES
Servo-Match function: servo centre, end-points and reverse for 4 channels and 8 servos
Graphic OLED screen with 128 x 64 pixels
Extremely user-friendly menu-based programming using the SensorSwitch
8 channels
Signal amplification and interference suppression for all 12 outputs
Variable frame rate, range 9ms - 21ms
16-bit processor for fast, high-resolution signal processing
double-regulated output voltages for receivers and servos
regulated voltage with selection facility, 5.9V or 7.4V
Connection facilities for Spektrum, HoTT and Multiplex MSB downlink bus systems
Direct transmission of battery voltage to the transmitter
Separate voltage display for each battery
Minimum value memory alerts the user to voltage collapses
Large-area heat-sinks for high regulator performance
Regulator monitoring, regulator error indicator
Support for four battery types: LiPo, LiIon, NiMH / NiCd, LiFePo
Suppression of any servo feedback currents which may occur
Updateable with PowerBox Systems USB Interface connectors
TECHNICAL DATA
Operating voltage 4.0V - 9.0V
Power supply 2S LiPo, 2S LiIon, 2S LiFePo, 5S NiCd/NiMH
Current drain Power-on state 130mA
Current drain Standby 15µA
Maximum load current Peak 2x20A
Drop-out voltage 0.3V
Output voltage 5.9V and/or 7.4V regulated
Channels 8
Servo sockets 12
Programmable servo outputs 4 channels, 8 servos
Servo signal resolution 0.5µs
Signal frame rate 9ms, 12ms, 15ms, 18ms, 21ms
Screen OLED 128 x 64 pixels, graphic
Supported telemetry systems Spektrum, HoTT, M-Link
Dimensions 110 x 72 x 24 mm
Weight 115g
Weight Sensor Switch 15g
Temperature range -30°C to +75°C
FEATURES
8 channels
TECHNICAL DATA
Channels 8
Servo sockets 12
Weight 115g
