Rage Imager 390 FPV RTF Drone New Years special
My Feedback: (850)
MO
Brand new in box Rage Imager 390 FPV RTF Drone, normally $199 blow out price at $139 shipped. Call text or email 314-256-9987 or [email protected]
<iframe width="520" height="315" src="https://www.youtube.com/embed/-nWpHHtI-n4?list=PL0hYGsPKGZZAw0syCZMHQods_eH873nzY" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
The Imager 390 FPV Drone is the perfect large, stable drone for FPV photography, videography, or simply fun flying. The robust 390mm size and a 6-axis gyro system combine to provide optimized stability, while standard features such as One-Touch Power-Up and Landing, Heading Lock, Return, and Altitude Hold allow pilots to spend more time getting the images and videos they want, and less time worrying about keeping the drone in the air. The Imager also includes LED lights for added visibility and orientation assistance, plus 3 flying rates to match your desired rate of control sensitivity. To capture videos and photos, the Imager has a factory-mounted 720p HD camera connected to a single-axis gimbal that can be remotely adjusted up and down from the transmitter to change the camera point of view as desired. The unique, ergonomically-designed transmitter expands to hold your smart device which receives real-time video via a WiFi link and app. Videos and still images can be recorded to your device via the app or to a micro memory card (not included) on the camera.
The Imager FPV is an RTF (Ready-To-Fly) drone, so it arrives factory-assembled with everything needed to get started capturing airborne video and images. Bolting on the camera and landing gear are the only steps required for completion. In addition to the extensive list of standard flight features, a 2S 2000mAh battery is included for extended flight times, along with a 1000mA USB charger for quick charging and removeable blade guards for enhanced flight safety. The transmitter features an internal rechargeable battery with dedicated USB charger, so all you need to do is charge the flight battery and transmitter and you can be experiencing stable FPV flight within minutes of opening the box!
Key Features
Altitude hold feature
One touch auto power-up-and landing
6-axis gyro allows for smooth, easy flights
Heading Lock for easier control when at long distances
Return feature reverses last flight control command
Unique 2.4GHz transmitter that expands to hold your phone for FPV viewing
Low battery alarm warning
Includes 2S 7.4V 2000mAh battery for long flight times
Includes 2 USB Chargers (1 for TX, 1 for flight pack)
Specifications
Total width: 390mm; 15 3/8 in. (diagonally from motor shaft to motor shaft)
Height: 165mm (6 1/2")
Weight: 1.5 kg (52.9 oz.)
Battery: 2S 7.4V 2000mAh Lipo battery
Motors: Coreless (4 total)
Transmitter: 4-channel, 2.4GHz with internal LiPo battery
Key Features
Specifications
