OS 33GT Gasoline Engine for Pattern
#602
My Feedback: (90)
By chance would someone have a links to the SASS 180 use in pattern by MTK? I tried searching without any luck.
I'm looking for some threads about taking wood electric props and modifying them to use with gas pattern engines. Reinforcement with carbon fiber.
I finished my engine swapping a DZ170cdi for the OS GT33 and all I can say is wow. Using a 19x11, not leaving much room for ground clearance. I found some 18x12 and a 18x13 electric props I would like to try.
Thank you.
Thank you.
#603
Thank you.
Thank you.
please post some photos of the model..
wattsup (02-07-2022)
#612
My Feedback: (90)
I have twenty two flights on it to date.
The first three flights on it the second time out I noticed a light oil down the sides and it seemed a little louder. Took the chin cowl off and noticed both clamps loosen and tightened. Even with the loose coupler the engine pulled the 11 lb plane straight up unlimited. With the tightened coupler it was a lot quieter and pulled even better.
End story, it was worth the change. Oh and all this on one gallon of fuel.
