Foam Wing Repair
MT
Foam Wing Repair
Question regarding Foam Wing Repair:
I have a Duraplane trainer which has a foam wing and had an unfortunate engagement with a metal post, which resulted in a deep gouge in the leading edge, approximately 1.5 inches long.
Does anyone have any thoughts as to an appropriate filler? Am currently looking at Hobbico hobbylite filler or K&B Micro-Balloons filler.
I have another wing kit but would like to repair the original as a backup? I appreciate any thoughts that may be provided.
DE
Foam Wing Repair
If looks do not matter to you use a business card and clear packing tape from Staples. Wrap the card over the LE and tape it down. I have seen and used this for a quick fix . . .It always lasts as long as there is no other structural problems. make sure you check the wing very closly, as a small crack may not be noticable. Good Luck!
Foam Wing Repair
Cut out a rectangular section of the leading edge, enough to remove the crushed pert. Glue in a pice of blue or pink foam and sand the profile to match the rest of the wing.
Ed S
Ed S
Foam Wing Repair
You could use expanding insulation foam. available at almost any hardware store. I use it for lots of stuff including: holding battery packs, fuel tanks, filling holes - whatever it's great stuff!!
Foam Wing Repair
Blue pink or even grey foams are different types of insulation foam. They all cut with a wire but are usualy heavier than white foam.
Be carefull of the expanding foam in the can. Even the low expansion type can do a lot of damage as it expands. It does need to be controlled. I squirted some into a molded wing once and the wing puffed up like a balloon.
Ed S
Ed S
My Feedback: (59)
VA
Foam Wing Repair
If you can't find the blue or pink foam, just cut a square chunk of soft balsa and glue it in the ding. Then sand it down to match the wing!
Just my .002 cents worth!
Happy flying,
Joey. :idea:
Happy flying,
Joey. :idea:
MT
Foam Wing Repair
Thanks for all the good suggestions. We will bring the wing back to life. And a special thanks to Russ-by the way, I couldn't find Montana, Arizona on the map.
Foam Wing Repair
Fill it with lightweight spackling from red devil, available at most hardware stores, you`ll know its the right stuff when you pick up the tub. It does`nt weigh hardly anything. Let it dry sand it back to what it should look like. JW
