Force RC F-18 Blue Angel EDF PNP Airplane-Only $70.00 new $180.00
My Feedback: (12)
Lightweight construction with durable EPO foam material
Aileron: Yes
Approximate Assembly Time: Less than 1 Hour
CG (Center of Gravity): 3.5 in (88mm) From Leading Edge
Charger: Sold Separately
Completion Level: Plug-N-Play
EDF Size: 64mm
Elevator: Yes
Flaps: No
Flying Weight: Around 660g (23.3oz)
Landing Gear: Yes
Length: 960mm (37.8in)
Material: EPO Foam
Minimum Required Radio: 4+ Channel (Sold Separately)
Motor Size: Brushless 2627-KV5100
Retracts: No
Rudder: No
Servos: (5) 9G Servo
Speed Control: 50A
Throttle: Yes
Wingspan: 710mm (28in)
#FCEF060001 - NEW-$149.99 My Price $70.00 + shipping
Watch it fly:
https://www.modelairplanenews.com/fo...f/#outer-popup
Send me your address and I will send you the cost of shipping. Pay Pal at [email protected]. I only sell inside the USA.
If no Pay Pall account then send a personal check. No Money orders please!
- Strong, two-piece removable wing with optional armament
- High-thrust, 64mm 11-blade ducted fan unit (installed)
- Powerful 2627-5100Kv brushless motor and 50A ESC (installed)
- 4-channel control with 5 micro servos (installed)
- Removable landing gear with steerable nose gear
- Full-range, 4+ channel transmitter
- Full-range, 4+ channel receiver
- 2200-2600mAh 4S 14.8V LiPo flight battery
- Suitable LiPo charger
- (1) Force RC F-18 Blue Angel EDF PNP Airplane
- (1) 50A ESC
- (1) 2627-5100Kv Brushless Motor and 64mm 11-blade Ducted Fan Unit
- (5) Micro Servos
- (1) User Manual
Aileron: Yes
EDF Size: 64mm
Elevator: Yes
Flaps: No
Landing Gear: Yes
Material: EPO Foam
Retracts: No
Rudder: No
Speed Control: 50A
Throttle: Yes
Watch it fly:
