Zenoah G230PU Front Seal Leak
I'm replacing the crankshaft bearings in this engine due to a leaking seal on the
front bearing.
Is there any reason not to use 2 sealed bearings at the prop end of the crankshaft ?
The engine originally has an open inner bearing and a sealed outer bearing. Dimensionally the two bearings are the same.
Thanks !!
front bearing.
Thanks !!
