Great Planes Gee Bee ARF With O.S. AX 1.20 Engine-Like New-With Major Extra Parts
Great Planes Gee Bee Ready to Fly Model
68 Inch wingspan
45 Inch Length
743 SQ. In. Wing Area
Actual Weight-10 Pounds 12 Ounces
All it needs is your receiver and some programming.
This model has 3 Flights on it-Never Crashed-Everything was new when built
Looks New
Built and flown by a mature modeler with decades of experience as a hobby shop owner and hobbyist.
O.S. 1.20 AX 2 Stroke Power-Provides Unlimited Vertical Performance swinging a Zinger 16-8 Prop and goes like hell.
Includes Power Box Muffler vented through the cowling bottom to reduce exhaust residue on the model.
Specifications:
Displacement: 1.20 cu in (20 cc)
Bore: 1.197 in (30.4 mm)
Stroke: 1.083 in (27.5 mm)
Practical rpm: 1,800-9,500
Output: 3.1 hp @ 9,000 rpm
Weight: 21 oz (650 g)
Servos:
Throttle HiTec HS-422
Elevators: (2) Hitec HS-425BB
Rudder Hitec HS-475HB
Ailerons:Hitec HS-425BB
Built with Robart Robo-Struts which reduces this plane's tendency to bounce on landing
Includes Foam work stand
Includes the following extra genuine replacement and original parts:
Dummy engine with pushrod tubes
Landing Gear Struts
Wheel Pants Pair
Cowling with plywood support rings
Canopy
Wings with ailerons and joiner plate
Original peel and stick decal sheet
This is an overpowered, hot airplane which requires a high skill level and concentration to fly. Not for beginners.
68 Inch wingspan
45 Inch Length
Looks New
Specifications:
Servos:
Landing Gear Struts
Wheel Pants Pair
Canopy
OH
Gee bee airplane
68 Inch wingspan
45 Inch Length
Looks New
Specifications:
Servos:
Landing Gear Struts
Wheel Pants Pair
Canopy
Im contacting you for my friend cole he is interested in the plane his # is 740-475-7127 cole Bryant, he would like to talk to you about the plane thanks greg, he is local
68 Inch wingspan
45 Inch Length
Looks New
Specifications:
Servos:
Landing Gear Struts
Wheel Pants Pair
Canopy
