XXXNT factory settings
ON, CANADA
RE: XXXNT factory settings
I don't have the settings right at hand but, as far as I know (and recollect), the High Speed needle setting is 3 turns out, Idle Speed is 5 turns out. That's what mine is set to and it works great. Obviously you may need to perform some minor adjustments to that, but it should work for you.
Cheers!!
Cheers!!
ON, CANADA
Those settings are correct as well, but if you check their Quick Start sheet, it will list different settings. I've tried both and found the settings on the Instruction booklet (included in this thread) to be far from ideal. Somewhere within those settings you should fine happiness. Just my opinion.
Good Luck!!
Good Luck!!
ORIGINAL: whitexj
cant remember, is the hsn the one on the front of the carb, or the one that does the fuel input?
