Aerofoam T-45
Aerofoam T-45
Old 06-08-2022, 03:09 PM
  #126
paulsf86
My Feedback: (52)
Not sure why adding more weight to nose moved cg back. I always balance right side up and use ez balancer or something similar. We both seem to have about the same amount of stuff up front.
Paul
Old 06-08-2022, 04:10 PM
  #127
F900
For sure, it's a strange one, last flight on rotation it was one of those oh **** moments, tail heavy.
Old 06-09-2022, 07:42 AM
  #128
paulsf86
My Feedback: (52)
I do not have picture right now but I also have two of the banana hobby pilots in the cockpit which adds more weight in the nose.
Paul
Old 09-06-2022, 06:55 PM
  #129
Andrewfordham
Hey guys, I just got one of these from a club member, it’s brand new and will be my first turbine. Do you guys feel like a gyro is necessary? Are the slats and air brake worth using as well? I noticed some people having issues with the gear, so far on the ground mine are working flawlessly, obviously things might change in the air. Any advice for flying it?
Old 09-07-2022, 04:31 PM
  #130
jvaliensi
I don't fly this model but I have the FW version.
I use a Cortex Pro. I like the way it works and it makes a stabilized approach for landing easy to achieve.
I think for the size, weigh and speed the slats and air brakes are feature that has little benefit.
My friend Andrewjet has great success with his T45. He knows all the tricks.
Old 09-07-2022, 06:45 PM
  #131
frankmokaya
Default Aerofoam T-45
Hi Andrew,
I had this jet and I can say that I do not think that it needs a gyro. If you set the throws per the manual, she flies pretty gentle. That being said, I did put an AR SmoothFlite 16 unit in it and tht made for a no fuss, easy, fly whenever, kinda plane. She's gentle so I would not be worried.
I used the slats and air brakes for my landings. Full slats and flaps for landing and half slats and flaps for take off. She did well. The air brakes you will notice have fairly weak linkage-servo mechanical advantage. Meaning that if you open then at speed they will just shut back up. So I found that I deploy them once on the ground just to get that scale look.
I have a few videos on Youtube on my T-45. Take a look and feel free to ask questions. https://www.youtube.com/playlist?lis...-2CXEMVWwIQKGz
Cheers,
Frank
ID:	2272228   Click image for larger version
Old 09-10-2022, 06:47 AM
  #132
Andrewfordham
Originally Posted by frankmokaya
Hi Andrew,
Cheers,
Frank
thanks frank! How did you feel it did power wise with the k85? The new k102 is tempting since it’s the same size.
As of now I have the slats mixed with flaps like you were saying, half flaps and slats, then full flaps and slats. I have the air brake set to deploy when I activate the wheel brakes
Did you have any issues with your elevator servo? Mine has been starting to shutter recently. I am thinking of replacing it with something like a savox 1270tg, 1230sg, or a mks ds9910. Would these be sufficient?
Old 09-11-2022, 05:51 PM
  #133
frankmokaya
I did not have any issues with my elevator servo but the the plastic that supports the elevator servo was busted. i fixed it no issues. But otherwise no issues there. If it's stuttering, it's wise to change it out.
I think any of those servos should work out if they fit. The only thing I'd say is because they'll likely have have more torque be very careful that the servo travel does not break the plastic bit in the elevator mechanism that couples to the metal rod that the elevators are bolted to.
Also one of my friends wound up balancing the elevator by embedding some weight into the leading edge. This way he was able to balance the elevator surface so it wouldn't droop when left alone. I did not do this either but my buddy Chris liked that it gave him peace of mind.
Old 09-11-2022, 06:13 PM
  #134
Andrewfordham
I saw your video on sanding some of the material off the elevator to get more throw, did you sand just enough off to get the suggested throws?
by chance did ever clock your speed with the k85?
Old 09-12-2022, 05:19 PM
  #135
frankmokaya
I did not clock the T-45 speed. Yes I had to sand my elevators a bit to get just a bit above the recommended throws so that I could be sure that no binding could occur with the recommended throws.
Old 09-12-2022, 06:39 PM
  #136
Andrewfordham
where did you end up setting your CG? The paper manual and pdf manual listed it differently.
Old 09-13-2022, 07:32 AM
  #137
Desertlakesflying
My Feedback: (28)
Be sure to double check your wing mounts for proper glue. Mine came loose after only a couple of flights. Thankfully there is enough overlap in the foam and the mount they don't move when they come loose.
Old 09-13-2022, 08:41 AM
  #138
Andrewfordham
will do, thanks
Old 09-13-2022, 12:52 PM
  #139
Desertlakesflying
My Feedback: (28)
Originally Posted by F900
I don't understand how your not been supported on these issues by either Ralph or Mike. What are we missing here?
Good luck getting that support, you aren't missing anything
Old 09-13-2022, 06:53 PM
  #140
F900
I gave up and sold mine, can't be arsed dealing with poor/sloppy workmanship, as I found out my main landing gear was not even glued in and other issues.
Desertlakesflying (09-14-2022)
Old 09-14-2022, 05:25 PM
  #141
Desertlakesflying
My Feedback: (28)
Yeah I was dumb enough to give them another shot with the L-39 and that was a bad idea The only support I got was getting blamed for garbage workmanship, and then trashed by one of the reps, and lied about by another.
Old 09-14-2022, 06:56 PM
  #142
frankmokaya
Hi Andrew. I ended up with my CG at 178mm (7 inches) as measured from the leading edge of the wing at the root (where wing meets fuselage) aft. Start there and adjust to your liking. And this C.G is with UAT full, gear down, fuel tanks empty and all flight equipment attached (all turbine, landing gear, BEC batteries e.t.c)
Old 09-14-2022, 07:15 PM
  #143
Andrewfordham
sounds good. Thanks for all the help!
frankmokaya (09-14-2022)
Old 12-18-2023, 04:01 AM
  #144
Chris1965
Default Nose gear doors
Hi guys.
I am restoring a T-45 and the nose gear doors have been removed and there is no servo in place.
Also there are three sets of doors in total front to back. How do they open and close.
any pictures or videos will be appreciated.
Old 12-18-2023, 06:12 AM
  #145
rhklenke
My Feedback: (24)
rhklenke's Avatar
Originally Posted by Chris1965
Hi guys.
The front doors open and close with a servo. I have mine set to oppen with the gear is moving and close when it stops, either up or down.
The aft doors close via a spring-loaded "trapeze" that the gear leg pushes on when it closes. Thus the doors are open when the gear are down and close when it comes up.
Bob
Old 12-18-2023, 06:37 AM
  #146
Chris1965
Thanks Bob. Any chance you could send me a picture of the setup. It isn’t obvious to me where the servo goes or how it attaches to the doors. Or where the springs go to the aft doors.
Old 12-23-2023, 05:46 AM
  #147
rhklenke
My Feedback: (24)
rhklenke's Avatar
Yes, I can do that. Give me a few days to get the plane down into my workshop so I can get a picture...
Bob
Chris1965 (12-23-2023)
Old 12-23-2023, 09:36 AM
  #148
Chris1965
Thanks Bob. Much appreciated
Old 12-30-2023, 02:09 PM
  #149
rhklenke
My Feedback: (24)
rhklenke's Avatar
Default T-45 nose gear pictures
Here's some pictures. The aft doors close with the spring loaded trapeze as these remain open with the gear is down. The aft doors open and close with a servo as these close when the gear is up or down. Obviously, my doors don't close 100%. What I have is as close as I can get to fully closed.
Bob
Last edited by rhklenke; 12-30-2023 at 02:11 PM. Reason: trying to attach pictures...
Old 12-30-2023, 02:22 PM
  #150
rhklenke
My Feedback: (24)
rhklenke's Avatar
Well, RCU doesn't seem to want me to upload pictures - I don't know why...
Bob
Ah, tried Google Chrome - here it worked...
I hate computers...
Last edited by rhklenke; 12-30-2023 at 02:31 PM. Reason: trying pictures using Google Chrome
