Park Flyers & Backyard Flyers Discuss RC Parkflyers and rc backyard flyers in this forum
Horizon Hobby Sport Cub S
Old 12-12-2014, 06:53 AM
JohnFM
Default Horizon Hobby Sport Cub S
Must be a few folks here have this little plane.
Anyone have any idea how to center one of those little linear servos it uses?
The elevator servo on mine is so far from centered when it's returned to neutral there's hardly enough stroke left in one direction to get elevator movement.
Every thing is all glued together so it's hard to figure things out and even the servos don't use a standard type plug so I can't even hook it up to my servo tester.
Old 01-09-2015, 06:04 PM
dacaur
dacaur's Avatar
check your radio trim and subtrim, if that's not it, sounds like you need to call and get a replacement...
Old 01-16-2015, 05:14 PM
Gadgeter
You can program that ESC/rec with a dongle if your so inclined. This would allow you to set center via the electronics which sounds like what you need. I would call horizon Great support usually
Old 01-16-2015, 07:48 PM
dacaur
dacaur's Avatar
Is this an assumption or have you done it? I'm curious because I have not talked to anyone that has tried it yet, would be good to know one way or the other....
Old 01-17-2015, 08:08 AM
JohnFM
So little activity here it's hardly worth checking, but this little HH model is so cheaply made, there's not a lot worth messing with.
All glued together on fragile styrofoam.
With some judicious bending of linkage wires I got this one good enough,
It's a relaxing little model to fly around on a nice dead calm day.
Old 01-17-2015, 05:32 PM
Gadgeter
I have the dongle and see where you can change all the default parameters for servos etc. I haven't had the need to change them until now/ I'm trying to make the controller from the Radian UMX run a plane with flaps like the Cub S. All that is programmed and should be able to be changed. I'll soon see
Old 02-05-2015, 04:45 AM
fishycomics
i hear you? One site. Has a ton of talk, and here not a lot of people.
Not ia pro but did you take the time to set the plane up and trim?
ii turn on craft let sit on a level surface, And see visually how the elevator looks? I work on the pushrods u bend. i do a short test flight and trim as needed. Repeat till trimmed. I as well get COG. Correct. Mark where my sweet spot is at till I get it near, then I electronically trim
bisco (09-19-2020)
Old 11-09-2017, 10:04 AM
superdow
I own two horizon hobby sport cub s and in beginner's mode the down elevator does not respond at all while flying. The only way to bring the plane down is to decelerate and rely on gravity. Horizon Hobby support says this is perfectly normal.
Old 03-13-2018, 02:00 PM
fishycomics
called a self landing in beginner's mode a protection if you want to decline switch to Intermediate.
Old 03-19-2018, 05:27 AM
Sarge50
I've got one of these, still sitting in it's box. Tomorrow is the first day of Spring so I guess it's time to assemble this little bugger.
Old 03-19-2018, 07:51 AM
fishycomics
Mn sits maybe oneday I'll get back out for some flights. can't remember what cam I put on her for air shots the #16 It was.
Old 03-19-2018, 08:37 AM
Sarge50
Oops. I don't have one of these. I have a Carbon Cub S+ waiting for assembly. My bad.
Old 03-19-2018, 04:00 PM
fishycomics
Lol either way it's a plane Lol
Old 09-19-2020, 04:09 PM
bisco
i had an s2, but it flew away. bye-bye.
Old 02-01-2023, 01:57 PM
kmeyers
kmeyers's Avatar
how well do they fly inverted?
Old 02-01-2023, 05:27 PM
bisco
mine flew great until i crashed it
Old 02-03-2023, 08:41 AM
kmeyers
kmeyers's Avatar
I'm flying mine indoors and I want to give it a try inverted.
Thanks for the reply bisco!
bisco (02-03-2023)
Old 02-03-2023, 09:20 AM
bisco
remember, when inverted, down is up, and up is down. don't make my mistake
Old 07-25-2023, 06:20 AM
bisco
until it isn't
Old 02-19-2024, 09:50 PM
kmeyers
kmeyers's Avatar
I flew mine 2-17-24 indoors at a very small space.
I looked at this thread again and thought I should give a +1 to working on the U-bend in the push rod. Squeeze or open while the trim is centered. Then when you have it close, then use the radio tim.
Better late then never.
Old 02-20-2024, 09:05 AM
bisco
not a lot of people, but very knowledgable veterans here
