Thrust adjustment
Thrust adjustment
Maybe this has been suggested b4, but what the heck...
Adding or taking away washers from the engine mount to adjust thrust angle can/ is a tedious job at best (IMO)... I made my task easier by cutting away part of the washer, making it kinda' "u" shaped. This allows the "shim" to be installed w/out taking the whole bolt loose.
OK??
OK??
RE: Thrust adjustment
ORIGINAL: rajul
Try Ernst thrust plates. No loosening over time and use. Very cheap too
http://www2.towerhobbies.com/cgi-bin...?&I=LXE953&P=7
WA
I started another thread similar to the thrust setting topic here. i like the Ernst thrust plates you can buy at Tower, but I wish they came in larger sizes for bigger engines. I think they only go up to the .60 range.
Patriot
Patriot
I like the washer idea. But I do have a reservation. It has been my experience that washers tend to sink into plywood firewalls over time and change the thrust adjustment. I use washer to initially trim the plane and then permanently replace the washers with a wedge sanded from aircraft ply.
The Ernst thrust plates work well. Some people use those plastic squeeqes for thrust plates too.
