Carf rebel pro
Carf rebel pro
Old 06-17-2024, 06:28 AM
  #776
Agrav8ed
I found this on thingiverse and printed it over the weekend on a lark. It was a great fit and seriously reduced the amount of grass inside my Rebel. Whomever designed it has my thanks.Tone
Old 06-23-2024, 04:43 PM
  #777
Desert Fox 1
Cheers!
Desert Fox 1
Old 06-25-2024, 09:31 AM
  #778
Ken Bryant
My Feedback: (10)
Ken Bryant's Avatar
Folks, can you please post up your interior layouts. I’ll be getting my plane in a month or two depending on shipping container availability. I’m pretty sure I have all the goodies to go in it. But it helps looking at other folks installs. Also helps in planning my install.
Old 06-29-2024, 06:48 AM
  #779
Ken Bryant
My Feedback: (10)
Ken Bryant's Avatar
Got pictures of my plane from CARF.
Old 06-29-2024, 02:53 PM
  #780
BarracudaHockey
BarracudaHockey's Avatar
Wicked!
Old 06-29-2024, 04:25 PM
  #781
sewbusy
Ken….I’ve been trying to upload a photo re your request, and have just been able to do so. This is how I did my setup on my Rebel Pro.
Wayne
The following 3 users liked this post by sewbusy:
GeorgiaFlyer (07-23-2024), Ken Bryant (06-30-2024), RickP (07-01-2024)
Old 06-30-2024, 12:15 AM
  #782
Jannica
Hello everybody!
I´m thinking about ordering a Rebel Pro. I know that the recommended engine range is from 180 N to 210 N but I certainly don’t need an engine in the upper range. My style of flying is gentle and taking use of dynamic energy in all manoeuvres and I generally think that many of our RC-jets are monstrously over powered. I also fly from a generous grass field.
I have a Kingtech 140 N G2 lying around and I wonder if that would be enough for a Rebel Pro?
Has any of you flown a Rebel Pro with a smaller engine than the recommended 180 N? And if so, what are your experiences?
And no, The Classic is not an alternative.
Jannica
Sweden
Old 07-01-2024, 05:20 AM
  #783
Ken Bryant
My Feedback: (10)
Ken Bryant's Avatar
Originally Posted by Jannica
Hello everybody!
I don’t imagine many if any have flown with a smaller engine than a 180. The smallest I can see get used would be a 170. I plan on using a Swiwin 190 and have been told the plane flies well with a 190.
Consider this, the average finished build comes in at 43lbs. The Kingtech 140 produces 32lbs thrust. The Kingtech 180 produces 35lbs thrust. The Swiwin 190 that I plan on is at 41. Swiwin 220 is at 48lbs.
Low power needs a very efficient wing and light wing loading. Possible, probably… enjoyable… not likely.
Jannica (07-01-2024)
Old 07-02-2024, 01:36 PM
  #784
RC_MAN
Mine had a 210. It is well suited for the PRO especially on takeoff with a full tank. I think 190 would be marginal.
Old 07-02-2024, 02:32 PM
  #785
smcharg
smcharg's Avatar
One must always consider altitude. You can lose 20% at 3000 ft. If you're at sea level, a 210 might be great. If you're at 3500 ft. MSL, you may want a 230ish in there.
Canadian Man (07-03-2024)
Old 07-03-2024, 04:06 AM
  #786
DAN AVILLA
My Feedback: (12)
DAN AVILLA's Avatar
I have a 190 SW in mine and I fly at 5000 ft . It has no problem. Just does not go vertical on take off. Dan
Jannica (07-03-2024)
Old 07-05-2024, 02:52 PM
  #787
Desert Fox 1
Cheers!
Desert Fox 1
Old 07-31-2024, 06:26 AM
  #788
why_fly_high
My Feedback: (19)
Well I bit the bullet and order a Rebel Pro. I have most of what I am going to run with figured out but the servos. Any suggestions for servos that have enough torque and fit easily?
Thanks!
Dan
Old 07-31-2024, 07:07 AM
  #789
Kenrico
Kenrico's Avatar
Thanks!
Dan
I have Savox 1270s all around in mines.
Old 07-31-2024, 08:08 AM
  #790
ECalderon
ECalderon's Avatar
Thanks!
Dan
Hi.
I have Savox 1270 in everything, excepto for flaps an rudder that have Savox 2290
Regards
Eduardo
Old 09-26-2024, 01:56 PM
  #791
Desert Fox 1
Cheers!
Desert Fox 1
