Electric retracts gears stripped
Old 07-01-2024, 01:45 PM
DHJ42
DHJ42's Avatar
Default Electric retracts gears stripped
Hi
I.m just getting back into things and purchased an older Top R/C F-9F Panther RTF. I watched the vendor cycle the gears but now the serve motor spins, you can hear the odd click, and of course it does not extend or retract the gear leg, which functions fine by hand.
Can I service the cylinder and replace the gears or can someone help me source a replacement?
Thanks in advance!
Old 07-01-2024, 04:15 PM
flyinfool1
flyinfool1's Avatar
Can you post some pics of what you have?
Old 07-01-2024, 07:07 PM
mongo
My Feedback: (15)
mongo's Avatar
if you are comfortable taking apart a modern servo, and replacing the gears in it, then the typical motor drive unit for the retracts will not be much difficulty for ya.
take pictures as ya dissemble it, and then it is easier to re assemble after cleaning and re greasing everything.
usually harder for me to source replacement parts, than it is to take it apart and re assemble it.
Old 07-04-2024, 06:30 AM
DHJ42
DHJ42's Avatar
Here are some pics of the unit. I have tried it disassembled 。 The servo motor seems fine. I think the issue may be with the servo gear and/or the gear reduction box. There are marks on some of the gears as well as at the end case bearing.
Old 07-04-2024, 10:38 PM
Vincent
My Feedback: (61)
Vincent's Avatar
Check with top rc they sell the motor assembly drive assembly. It’s possible a JP motor might fit too.
Old 07-05-2024, 02:05 PM
mongo
My Feedback: (15)
mongo's Avatar
i have had good luck using JP motor/drive units in other retracts...
however, as always,
YMMV
