New TopRC T-28 Trojan
Old 05-17-2024, 03:35 PM
  #301
Summer113
Summer113's Avatar
Thanks so much. Sounds like a good selection.
Old 05-19-2024, 09:27 AM
  #302
misu77
Hallo,habe mir auch die Trojan bestellt und bin von der Qualität begeistert. Kann mir jemand sagen welche Servos ihr verbaut habt und wie viele?
Gruß
Michael
Old 05-19-2024, 01:13 PM
  #303
planenutzz
read back through the thread, the info is there
Old 05-19-2024, 01:28 PM
  #304
planenutzz
Linkage for ailerons are in, just need to connect to servo arm and adjust.
I made test rig to see where the best place for the linkage on leading edge would be, middle seems to be the sweet spot.
Old 05-20-2024, 12:43 PM
  #305
planenutzz
Having issues with geometry for ailerons with the internal linkages, a number of factors at play and remediations steps I will take.
1. I put the the location of control horns in the middle of leading edge, they should be hard up against the bottom aileron skin as you can get it, i.e furthest from the hinge pivot. I'm getting another set of horns and will grind the existing ones down with the dremel.
See photo, the horns need to go hard against the very right hand side skin in the photo.
2. I made the hole in control horns slightly too large, not by much but it does allow a small amount of slop. I will drill and tap M3 with the next set of horns so there is no slop.
3. Servo arm is far too long and and the small amount of gear train and other slop movement is amplified by this length, I will experiment with locations till I only have enough travel for the flaps and will drill / tap a new M3 hole to suit in the alloy arm.
4. Lastly and thanks to Jason for pointing this out the servo hatch is far too flexible for the loads it will experience, I am going to laminate 2 layers of heavy weight carbon cloth to the bottom which will stiffen it up immensely, I will also add a second pair of mounting holes on the long sides. (will also do this to the flap hatch)
5. I may also consider adding a strip of 1/8th balsa sheet along the inside of the wing skin trailing edge just before the hinge point in case there is a bit of flexing there. Undecided on that yet.
This is my first crack at a very large model with very scale control surfaces so has been a learning curve.
Grateful I received very sage and experienced advice from a few people, Ross & Jason who is on this thread.
I got told yesterday there are a couple of these with I assume similar setup for ailerons and they experienced severe aileron flutter, one at Joe Nall during maiden flight, it only did 1 circuit but got down ok.
Failing all the above working I will install external G10 horns and linkage that way.
Live and learn.
misu77 (05-21-2024)
Old 05-21-2024, 04:39 AM
  #306
Summer113
Summer113's Avatar
So, are you going with external control horns, for ailerons … and possibly flaps …. Or, are you just moving ail control horn close test to skin ( far right in your pic) … to prevent flutter
thanks
mark
Old 05-21-2024, 12:38 PM
  #307
planenutzz
Flaps are done though I will reinforce the hatch and will shorten the attachment point on the servo arm.
I am working through the options outlined previously for internal linkage. New control horns are being fabricated and I will get a set of external horns as a fall back option.
misu77 (05-21-2024)
Old 05-25-2024, 02:02 PM
  #308
planenutzz
As I need to get more control horns made I have started on wing cabling and doing the 16 pin connectors. Very time consuming but could be the round MIL spec types I trained on back in late 80s.
The female plug receptacle will be screwed to the face of the centre section and I will open up a slot in the outer wing face to accept that without binding.
Old 05-26-2024, 02:46 PM
  #309
planenutzz
Spent most of yesterday doing wiring on outer panels, they are pretty much done apart from securing the loom within the wing.
Have started on the centre section, there is a lot going on in there with wiring and taking my time working through it.
There will be 3 main looms that come out, each with a 16 pin connector and these will feed up inside the fuz.
There will also be the battery lead for the retracts controller as that will be located inside the speed brake bay.
Using a JR HV multi box to drive the 3 nose door servos and it is fed from the retract controller, allows fine tuning of end points separately.
Wish I had more of the HV version.
The nose doors are split so centre section can be removed. There is a nylon torque tongue that joins them.
Not sure on location for switches yet, I have the powerbox main switch and 3 other accessory switches to place.
I was thinking access them via the open speed brake but have them fitted to the fuz wall or . . .
Access within the fuz by removing canopy and cockpit tub.
totka (07-08-2024)
Old 05-27-2024, 03:04 PM
  #310
planenutzz
more wiring. First loom is in the wing. I had to remove the flexible cover as the leg was pushing on it and not closing properly, have laid the cables flat against wing skin and secured in place.
Photos showing the new label maker, very happy with it and it is a piece of piss to use.
Old 06-02-2024, 12:44 PM
  #311
planenutzz
Wing wiring looms are done. There are 3, one each for outer panels and one that is the aux functions within centre wing, nose retract, nose door, brakes, retract signal etc.
Still need to tidy up a few things with cable ties but need to complete final programming of the JR Multi-box to nose gear door first.
The loose wires on one loom are for the controller battery input.
The TopRC retract controller has also been fitted with double sided tape.
Next job will be to fit servo for that little nose gear door and set its throws.
Old 06-04-2024, 04:11 PM
  #312
planenutzz
made a start on the front gear door mechanism, the concept works ok though a servo with a little more torque would be good. This micro digital servo is 3.8kg but is super small in size which I need as there is very limited room.
I do have savox mini servo which is about 10kg however I think it will be too large.
I'll play some more with it and see. I do need to flip it over so that the shaft is towards the front and move the servo closer to the opening. I would like the door to open a bit more than it does however the way I did the hinging prevents it, it goes over centre about 15 degrees which is ample.
Old 06-05-2024, 08:11 PM
  #313
planenutzz
Have changed the nose door servo to a Savox 1250 mini which is 8kg @7.4v, yes it's overkill but it is working a lot better than the tiny micro Dual sky servo.
Will be starting on the fuz fitout next. Still waiting on new aileron control horns to be sorted, no rush as I have others things to get on with.
Old 06-09-2024, 12:21 PM
  #314
planenutzz
ok change of plan with nose gear servo, had to go back to the Dualsky DS169 micro servo as the nose leg steering mount was fouling on the larger mini sized servo.
All is in and working fine, did multiple cycles, adjusted linkages on the long doors a little.
Now onto the fuz fit out.
The following 2 users liked this post by planenutzz:
misu77 (06-09-2024), totka (07-08-2024)
Old 07-01-2024, 12:56 PM
  #315
planenutzz
Gents, double check your aileron for slop so you do not get flutter. Another chap who has one nearly lost his as a result. I'll leave it for him to chime in with photos if he likes.
I'm re-doing mine, will post the result of that once done.
Have not really got a lot done, powerbox SR2, it's display and switch is finally in as are the 3 x switches for other functions I want to be able to isolate. These switches are heavy duty and have XT-60 connectors.
I'll be starting on fuz wiring very soon and also placement of the 4 x 6400mA/h Lion 7.4V packs.
JRSmith (07-01-2024), totka (07-08-2024)
Old 07-06-2024, 02:26 PM
  #316
planenutzz
Work continues on the wiring and getting it loomed in. Can't complete wiring for a while as I had to send the Unilights controller back.
JRSmith (07-06-2024)
Old 07-07-2024, 01:06 PM
  #317
planenutzz
Spent weekend working on the wiring and getting the bulk of it roughed in. Still a lot to do and will need to change the channel assignments I was going to use in the JR 12X.
AIL, ELEV & FLAP instead of being on separate channels will be changed to be a single channel assigned in the 12X for each and I will do the splitting and end points etc in the PowerBox Competition SR2.
I was simply running out of channels!
I have the wiring schedule printed out on my bench and as each connection is made I "greenline" it. Well yellow as that is the only highlighter pen I could find.
Still to do:
- Throttle
- Choke
- Ignition / fuel pump
- lights & program U*nilights 8ch controller when new one gets to me
- wiring into the nose steering, front gear door servo, nose retract.
- PowerBox programming.
Old 07-07-2024, 02:15 PM
  #318
JRSmith
My Feedback: (47)
JRSmith's Avatar
Looking great Peter, keep up the great work and thank you for taking time to share with the group! Talk soon!
Old 07-07-2024, 02:57 PM
  #319
planenutzz
thanks mate, need to be in the mood for this work and for having the x3 goggles on all day in order to do all the terminations. Time I called it stumps yesterday it was just on dark and I was at the point where I knew I would make mistakes if I pushed on.
Hope all your baseball events are going well.
cheers
me
Old 07-09-2024, 02:34 PM
  #320
planenutzz
A lot of progress done on wiring. Have transferred my wiring schedule markups to my spreadsheet including the greenlining.
JRSmith (07-09-2024)
Old 07-09-2024, 06:35 PM
  #321
JRSmith
My Feedback: (47)
JRSmith's Avatar
cheers
me
I have to use magnifiers as well to build my harnesses!
Baseball is super busy, we have one tournament this weekend and then travel to Reno for the final big tournament! Then we are done for the season and get about three weeks off and then into Fall baseball season and training for the 2025 season! Lot's of time, but this is his passion and does not want to do anything else. Talk soon!
Old 07-09-2024, 06:41 PM
  #322
planenutzz
There was a time when I was a RAAF tech that I could could work on the most minute of electronic equipment without glasses, let alone magnifiers. Not including micro min repair work as that was all done with x 3 magnifiers or greater.
I need to fit engine temporarily so I can work out throttle and choke servo placement. I'll make a little shelf with enough room for fuel pump and the iGyro as well.
It might be painful at times for you and your wife but in the years ahead these will be the good times you all remember and he will too! Hat off to you for doing it!
Old 07-15-2024, 01:27 PM
  #323
planenutzz
Not a lot to report though have re-sprayed the hatches and starting on the trim colours. Black for the V done and have started touching up the bit of the stars and bars on opposite side aileron hatch.
\More wiring also done.
Need to make a shelf to mount throttle, choke servos, fuel pump. Engine to be fitted for that so I get heights correct.
JRSmith (07-15-2024)
Old 07-17-2024, 02:36 PM
  #324
planenutzz
Have installed the new aileron control horns that Jason for Kehlar Designs kindly made for me. There are now in with hysol and hard up against the bottom skin of the aileron, i.e furthest away from the hinge point.
Servo arm hole is now at 1", I did try to do it at 3/4 but was fouling on the arm centre as that protrudes quite a bit and would have to use a long bolt with standoff nuts to get the clearance, the moment arm of that was far too long.
The good news is that the slop in the ailerons is almost gone, maybe 1/8" up and down which I can live with.
I extended the length of the horn ends so that they go in deep. Looks a bit messy but is functional and you won't see it !
Old 07-21-2024, 03:23 PM
  #325
planenutzz
Beed fiddling with the servo tray for the choke & throttle seros & fuel pump and getting those linkages done.
Installed the Rxrs & wired back to the Powerbox.
Will terminate the end of the cables for throttle and choke next then start to work out how to do the baffles.
Can't finish the working as I need the Unilight 8ch lights controller to be returned and for some reason the idiots in our customs have sent it back to me.
Also need to order the telemetry bits.
Probably time to get my test stand set up and fire up the UMS 180 and get the initial run in procedure done.
JRSmith (07-23-2024)
