BVM Plug and Play F16
Old 02-25-2021, 01:17 AM
  #376
flyrcjets
My Feedback: (30)
flyrcjets's Avatar
Does anyone have operating speed brakes on their 1/6 F16's? Was it ever an option?
Old 04-14-2021, 02:46 AM
  #377
Desert Fox 1
Cheers!
Desert Fox 1
Old 04-14-2021, 10:33 AM
  #378
Zeeb
My Feedback: (41)
Zeeb's Avatar
They are available on the 1/5th size model but I do not believe they were ever available on the 1/6th size models.
Old 04-14-2021, 01:16 PM
  #379
flyrcjets
My Feedback: (30)
flyrcjets's Avatar
They were available through Global Jet Club. I have a set of them, but I'd like to know more about the installation. This is what I have so far..
Old 04-14-2021, 09:16 PM
  #380
Zeeb
My Feedback: (41)
Zeeb's Avatar
Well I got the BVM version of the 1/6th size F16 when I bought mine, so I'm not going to be able to help you. Considering the attach method for the 1/6th vertical stab on the 1/6th, making operational speed brakes would be a challenge as the above poster mentioned.
Old 04-14-2021, 11:02 PM
  #381
flyrcjets
My Feedback: (30)
flyrcjets's Avatar
I'm the above poster and the one asking the question. No worries, I found the info I needed.
Old 04-21-2021, 04:29 PM
  #382
Desert Fox 1
Deleted
Old 04-21-2021, 05:26 PM
  #383
Zeeb
My Feedback: (41)
Zeeb's Avatar
Originally Posted by Desert Fox 1
https://youtu.be/cRu8AYbZXkk
Cheers!
Desert Fox 1
Dummy.....
You already posted the video and the model as specified right on the screen here, is that its a I/5th SCALE, not a 1/6th scale as we're talking about in this thread.
Old 07-10-2021, 06:15 AM
  #384
Desert Fox 1
Cheers!
Desert Fox
Old 10-10-2021, 05:55 PM
  #385
flyrcjets
My Feedback: (30)
flyrcjets's Avatar
Default Center tank
Can anybody tell me how they mounted the center tank on the BVM JL F16 1/6th scale.
Seems very weak and hard to get to where the holes are.
Thanks..
Old 10-11-2021, 06:15 PM
  #386
Zeeb
My Feedback: (41)
Zeeb's Avatar
Thanks..
The center tank? Mines got four tanks, two in back and two forward on each side of the centerline. Since I put a JetCat 180 in mine, I converted one of forward tanks to fuel and left the other as smoke fluid, as a friend told me; you CANNOT have a Thunderbird without smoke...... lol
Oh, for what it's worth; mine is the PNP version.
Old 10-11-2021, 06:34 PM
  #387
flyrcjets
My Feedback: (30)
flyrcjets's Avatar
Im talking about the external center tank.
Old 10-11-2021, 06:35 PM
  #388
flyrcjets
My Feedback: (30)
flyrcjets's Avatar
And yes more fuel is good. I have 180 also!
Old 10-12-2021, 05:56 PM
  #389
smchale
My Feedback: (67)
smchale's Avatar
Thanks..
i mounted a pair of BVM 1” knurled threaded inserts into the bottom of the fuse.
then i took a long 4-40 bolt and cut the head off and filed a flat on one end (like you would for a wheel axel). That then threads into the fuse with the end with the flat sticking out and to one side. My pylon has a set screw in the side that tightens against that flat. The tank stays mounted to the pylon.
So to install i thread the headless bolts in, then slide the tank/pylon assembly on and tighten the set screw in the pylon. Hope that make sense. The silver paint shows me when to stop screwing the headless bolt in.
Old 10-12-2021, 06:34 PM
  #390
flyrcjets
My Feedback: (30)
flyrcjets's Avatar
Thank you for sending the information!
Ok that would work but curious how you got up in the fuse or was it empty when you installed the inserts.
My holes are on the back sides of the formers that is impossible to reach with everything installed.
Old 10-13-2021, 02:43 AM
  #391
smchale
My Feedback: (67)
smchale's Avatar
It was so long ago, but without the turbine in it’s accessible to both locations. One is right in front of the former that holds the back of the inlet ducting and the other is right behind the rear LG former. I used a long 3” 4-40 bolt in one end of the insert to guide it in position and then another screw in the bottom to hold it tight. The long screw also helped me make sure it was vertical before gluing. Then i added a bead of hysol around the knurled spacer. Once cured i could remove both bolts.
Old 10-13-2021, 06:28 PM
  #392
Zeeb
My Feedback: (41)
Zeeb's Avatar
It's not difficult to remove the Turbine from this model, maybe that would allow the access you need?
Old 10-13-2021, 10:41 PM
  #393
flyrcjets
My Feedback: (30)
flyrcjets's Avatar
Yep, I have removed the turbine, helps on angle, but it's the stuff on the other side of the formers at the bottom of fuse and the fact the holes are right up against those formers. Pretty small holes so can enlarge them or move them.
I was thinking similar to Sean's method, and the way the wing tanks are done with tabs that hang, and the pylon is slotted to fit with a hole/screw on the side to secure.
Old 10-13-2021, 10:46 PM
  #394
flyrcjets
My Feedback: (30)
flyrcjets's Avatar
So I guess they put those holes there on all of them! I like that you can hold it all in place while it sets up. I'll check it out, thanks!
Old 05-12-2024, 03:40 PM
  #395
jorgeelizondom
Hi,
Is anybody successfully using smoke tanks as additional fuel tanks?
If so, are you using High flow?
Old 05-12-2024, 04:37 PM
  #396
flyrcjets
My Feedback: (30)
flyrcjets's Avatar
Originally Posted by jorgeelizondom
Hi,
Yep,
I run only one smoke tank for smoke, the other as additional fuel for the K180G4. I re-plumbed it all but used the standard fuel line size and fittings.
Old 05-13-2024, 11:56 AM
  #397
Zeeb
My Feedback: (41)
Zeeb's Avatar
Hi,
Mines got the same mod flyrcjets mentions, one forward tank converted to smoke oil, it's not a lot so the smoke won't last long but mine's a Thunderbird scheme and a friend said it "HAD" to have smoke......lol
The other forward tank it fuel along with both rear tanks being fuel as mine's got a JetCat P-180RXi. High flow fuel line stuff isn't necessary until you get above 220N size Turbines, the 4mm stuff is just fine. In fact, they were running the 220 JetCats on 4mm line with no issues which is great as messing with that larger diameter line and how stiff it is, is a real pain in the butt to work with..
Old 07-01-2024, 01:17 PM
  #398
Desert Fox 1
Cheers!
Desert Fox 1
Old 07-23-2024, 11:33 AM
  #399
jorgeelizondom
Default Different pressure measured in CCU and analog gauge
Hello guys,
I got a very nice, used F16.
Pressure reading on the CCU is much lower than the one from the analog dial.
For example, the CCU reads 80 psi while the analog gauge reads 105.
I should mention that my cheapo compressor gun agrees with the analog dial.
Is this large variation normal?
Thks for your comments
Old 07-23-2024, 05:28 PM
  #400
Viper1GJ
My Feedback: (20)
Viper1GJ's Avatar
This is normal for all the BVM CCU jets I have operated. My friends say the same for theirs. I used 95-100 psi on the round guage which usually gave 70-75 psi on the CCU. I did not experience it but higher pressure could cause lines to blow off fittings or air blow by the pistons inside the cylinders.
jorgeelizondom (07-23-2024)
