JEEMO Turbine Glider Set Up
Old 04-01-2023, 03:31 AM
  #101
zx6rg2
Default Jemmo
Hi could anyone tell me if you have used the heat cloth that’s supplied with the kit and if so how have you fitted it thank you
Old 04-01-2023, 05:19 AM
  #102
Speedrick
Hi,
Surely used the provided hig speed tape - protection shield on the area, close to the exhaust.
Applied it as a normal decal, water with some cleaning detergent product, so you can slide it until it fits as you want.
Then squize the fluid under the tape with a spatula and let it dry overnight. Works nicely.
Old 06-06-2023, 01:37 PM
  #103
LewisE1
What set up are people currently using ? C of g movements and flaps, are people using the flaps on a slider too. ?
Old 06-07-2023, 12:26 AM
  #104
Didier
-CG slightly forward of recommended by Glider-It.
-Flaps/crow as recommended by Glider-it
-Landing mode condition: Flaps/crow proportional controlled by my throttle stick. Stick middle to up is turbine idle to full power.
Stick middle to down:
1 turbine stays idle or off.
2 Flaps/crow neutral to deployed (fully proportional).
Works amazingly.
Old 06-07-2023, 12:51 AM
  #105
LewisE1
Thanks for the info, so having proportional crow and flaps is essential ? or just a nice to have ?
Old 06-07-2023, 01:08 AM
  #106
Speedrick
Hi,
All the same as Didier, but programmed a “Landing” flat mode, which deactivates the turbine control from the throttle stick function. (Normally, the turbine is at idle or OFF for landing)
In stead, the throttle function controls my butterfly in this landing mode, so I can keep the thumbs on the sticks at all time.
Just one remark is that I’m suspecting a incorrect incidence angle of the stab. In every phase, the elevator had to be trimmed up about 2mm, which is way to much.
Shifting the CG gives no change. Plan is to measure the incidence later this week, and adapt the stab accordingly. Suspect I’ll have to shim 1mm approx.
my s/n of the Jeemo is 2049, and I know that a fellow Jeemo pilot, with a slightly newer one had to trim up around the same.
Old 06-07-2023, 11:31 PM
  #107
LewisE1
one more question are the aileron measurements of 15mm up and 10mm down being measured at the tip or root ? seems a lot if at the tip ??
Old 06-08-2023, 02:00 PM
  #108
Speedrick
Hi,
Certainly at the root of the aileron.
Donˋt forget to dail in some expo too, this will smoothen the turns.
Greets,
Eric
Old 07-31-2024, 05:41 AM
  #109
zx6rg2
Default Jeemo
Hi all has anyone installed a wheel on the jeemo as like the one ail was flying ,that could pass on details ect
Old 07-31-2024, 02:28 PM
  #110
DrScoles
My Feedback: (18)
DrScoles's Avatar
I just got Jeemo #2. Planning on using a fuel bag on this one. Has anyone done this yet???
Old 08-01-2024, 04:04 PM
  #111
LimitDwn
My Feedback: (21)
Originally Posted by Speedrick
Hi,
Speedrick, have you measured the incidence angle and if so what was the outcome?
Robert
Old 08-05-2024, 11:32 AM
  #112
RCISFUN
My Feedback: (44)
RCISFUN's Avatar
Any updates / photos of the install?
Old 08-08-2024, 06:42 AM
  #113
Bobo20evo
Default Fichiers
Bonjour, serait-il possible d’avoir le fichier de l’aménagement intérieur du jeemo svp ???
Old 08-10-2024, 07:20 PM
  #114
Speedrick
Robert,
initially, as measured, incidence was at -1.2°!
now after correction, it is at +0,8°
cheers,
Eric
Old 08-12-2024, 05:50 AM
  #115
RCISFUN
My Feedback: (44)
RCISFUN's Avatar
Robert,
cheers,
Eric
Do you have any photos of what you used to correct?
Old 08-12-2024, 05:55 AM
  #116
Bobo20evo
Default Rcisfun
Hello Eric, could you send me the cutting file for your wooden supports for the inside of the Jeemo please?
(I can buy it too)
Old 08-12-2024, 06:23 AM
  #117
Speedrick
(I can buy it too)
No cutting files for this unfortunately.
I just cut the provided plywood plate to my requirements😛
Old 08-12-2024, 06:28 AM
  #118
Bobo20evo
I was RCisfun thinking of asking, but unfortunately I don't know how to do it on this forum😝 sorry
Old 08-12-2024, 10:55 AM
  #119
LimitDwn
My Feedback: (21)
Hello Eric, first thanks for the info in the incidence and yes I’m no expert in this subject. Can you tell me about how much the leading edge of the horizontal stab was raised to get the corrected incidence reading that you now have.
Robert
Old 08-12-2024, 08:25 PM
  #120
Speedrick
Well, during the maiden flight, I found out that 5mm up trim was needed for level flight.
This quickly made me think about the incidence of the stab. I then started to add strips of masking tape
onto the back of the platform where the stab is mounted, centered over the aft attachment bolt of the stab.
These strips allow to fine adjust the incidence till no up trim is required any more.
in my case it ended up with approx 2.3mm of thickness. Will post some pics once I’m back home.
Old 08-13-2024, 07:41 AM
  #121
RCISFUN
My Feedback: (44)
RCISFUN's Avatar
If you want the files for the plates I made send me your e-mail address in a PM.
Old 08-13-2024, 07:44 AM
  #122
RCISFUN
My Feedback: (44)
RCISFUN's Avatar
Interesting, I wonder what changed with your fuselage? Mine only required a very very very small amount of up trim...
Old 08-13-2024, 09:27 AM
  #123
LimitDwn
My Feedback: (21)
Thanks for the information, I look forward to seeing the pics. I will perform a test fight first and see where the trim ends up and if required will start the shimming process as you did. With a little luck should be ready for maiden in two weeks.
It would be interesting to know if other Jeemo owners have same up trim requirement.
Robert
Old 08-15-2024, 11:55 AM
  #124
Speedrick
This is how it looks like, the masking tape stripes
Old 08-16-2024, 05:01 PM
  #125
LimitDwn
My Feedback: (21)
Thanks for the work in figuring this out and the pics.
Robert
