Skygate/CARF Viperjet
Old 07-10-2021, 03:12 PM
  #701
ECalderon
ECalderon's Avatar
Hi, I also fly ate 600 mt above sea level. My landing flap is about 65º-70º and I use about 5 mm crow with elevator mix (about 2 mm up elevator) only for landing flap. I have a Jet Central Cheetah 160. For landing, on upwind I lower the gear, when it is down I go to take off flap ,and once in downwind go to landing flaps between 1/4 and half throttle depending on wind. On final I keep the throttle at about 1/4 managing altitude with throttle so that it touches down a little past me. When I know I have reached the runway I go to Idle, usually at about 2 mt altitude. Some time we have a lot of wind and to bring it in throttle on final has to be more, it slows almost to a crawl with no bad habits.
Regards
Eduardo
DenisFerrari (12-23-2021)
Old 07-10-2021, 11:07 PM
  #702
Dave Wilshere
If you have 2mm UP mixed with flap you are running nose heavy.
The Viper’s huge tail hides this situation well, it’s why people have been flying this aeroplane nose heavy since it was designed.
Dave
DenisFerrari (02-01-2022)
Old 03-25-2022, 08:02 AM
  #703
Hans Hilmar
Hi Guys,
Very helpful tread, thanks for that! Just a quick question, what size pilot will fit this plane?
Hans
Old 03-25-2022, 08:16 AM
  #704
Asif
My Feedback: (30)
Originally Posted by Hans Hilmar
Hi Guys,
Hans
I have 1/4 scale pilot from warbirdpilots.com The pilot is 15" tall and fits just fine in my Viper.
https://www.warbirdpilots.com/Search...ilot-Red-White
The following 2 users liked this post by Asif:
DenisFerrari (03-25-2022), Havilland (08-23-2024)
Old 03-25-2022, 08:21 AM
  #705
Hans Hilmar
Thank you so much!
BR. Hans
Old 01-20-2023, 06:51 AM
  #706
Dave Wilshere
Near 10 year old CARF Viper brought up to date. It was in quite a state when it came to me for a running issue. Cleaned and polished, new canopy, totally ripped out and re wired with Powerbox wire, Mercury fitted, changed to Core. Fuel system was rebuilt and turbine serviced at JetCat. Ready for another 10 years!
The following 2 users liked this post by Dave Wilshere:
DenisFerrari (01-20-2023), paulhat (01-20-2023)
Old 02-27-2023, 10:36 AM
  #707
Dave Wilshere
Test flight done…does not look it’s age!
DenisFerrari (04-03-2023)
Old 02-27-2023, 11:15 AM
  #708
A7Bldr
My Feedback: (40)
Dave, I bet by now you can test fly these "Blindfolded".
Jim
Old 02-27-2023, 02:04 PM
  #709
Bob_B
Bob_B's Avatar
Dave is that a 2m Viper Jet
Old 03-03-2023, 12:04 PM
  #710
Dave Wilshere
Jim
Jim
Yep…probably don’t even need to be on the airfield 🙂 Set up correctly they are just like flying a leather arm chair. The owner will be shocked when he next flies it as I moved around 12oz of batteries from the nose and put them by the fuel tank! It flies even better with a correct balance.
Bob, no CARF Viper’s are all 2.6m
Old 09-07-2023, 09:06 PM
  #711
damagedgoodes
Default Help with Unilight installation
Can anyone help with spar position in the wing please and how you routed the cable? I’d like to install Unilight nav/strobe units on the ends of the wings but I noticed the wing is sealed outboard of the aileron servo. I also want to make sure I’m either in front or behind the spar when I cut a slot in the wingtip. Any help would be appreciated.
Old 01-08-2024, 06:57 AM
  #712
Dave Wilshere
DenisFerrari (01-08-2024), Hans Hilmar (01-08-2024)
Old 01-08-2024, 07:38 AM
  #713
A7Bldr
My Feedback: (40)
Love it when you skid around the corner with the rudder on the slow passes!
Bob_B (01-09-2024)
Old 01-08-2024, 09:48 AM
  #714
Dave Wilshere
There was a cross wind that day from memory, but slow turns with a jet is all about the rudder…it’s why so many run into trouble trying to fly slow, they just use aileron!
DenisFerrari (01-11-2024)
Old 01-09-2024, 05:25 AM
  #715
jvaliensi
Do these photos help?
https://carf-models.com/en/products/viper-mk2
Old 06-20-2024, 07:04 AM
  #716
Afterburners
Afterburners's Avatar
Wondering if anyone has or can take a pic of their Electron nose gear/servo/linkage setup? I pulled my ER-40's from a Carf Hawk and contacted Electron as to what needed to be changed for this Viper and received the parts. For the nose gear, all that Adrian from Electron said needed to be changed was the servo mount which is offset to lower the servo. Even with that I have to mount the servo from below the mount(not pass the servo body through the mount) for the servo arm and linkage to clear the fuse skin and it's still very close. Just curious if I'm missing something mechanically. Thanks.
Old 08-06-2024, 12:22 PM
  #717
Hans Hilmar
Originally Posted by Dave Wilshere
Way back! Fuselage with no wings or spar, tails on and a little fuel in main tank. Balance on the wing fixing 6mm hole in the fuselage
Hi Guys,
Just need at little confirmation here to be sure I get this right, trying to use Daves method to balance my Viper. Does it sound correct that I will end up with batteries mounted approx. at back seat (Front part of Fuel tank) or I'm I way off here?
Flying now with batteries mounted next to front gear, plane flies fine but seems nose heavy when landing so want to move CG further back.
Thank you so much in advance.
Old 08-06-2024, 09:09 PM
  #718
Dave Wilshere
Hans
Yes, it depends on servos etc, but I have several friends with all three batteries on the fuel tank when using JR 8411’s in the tail.
Dave
DenisFerrari (08-10-2024)
Old 08-07-2024, 12:39 AM
  #719
Hans Hilmar
Hans
Dave
Sweet! Thank you Dave..
Old 08-23-2024, 01:31 AM
  #720
Havilland
Hello everyone, I also built some cockpit components for the XXL Viper and also the XXL Viper from Skymaster.
Old 08-23-2024, 04:48 AM
  #721
jvaliensi
Hi,
What servo torque is needed for the flaps and elevators? I imagine the flaps need more torque. I have some 355oz servos that I am thinking to use in the stab and 550oz for the flaps.
This airplane has been around a long time and servos have gotten much more powerful since then.
Old 08-23-2024, 01:28 PM
  #722
Dave Wilshere
More than enough. Flaps the geometry is more important than torque
Old 08-31-2024, 03:39 PM
  #723
jvaliensi
I started to build my Viper. Thanks to Elad for getting it so quickly -I ordered it on Monday and picked it up Friday. It took a little more than a week for the retracts, tank and pipe to come from Germany.
The factory photos of the Pioneer scheme do not represent how good it looks in real life. Actually, it was my least favorite scheme, until I got it. Two other fellows have the Cayman scheme and I needed something different.
It is amazing to me how perfect the paint lines line up. The parts are coming out of separate molds and are painted in the molds.
The pipe system is quite clever but can be improved by having more area to attached the turbine mounts. I had to graft on extensions for the rear bolts.
Apparently Inspector 14C left early the day they checked my model - as the wheel well cut-outs on the fuselage are absent. Ha, more fun for me.
The paint work is amazing.
See how the rear tabs are where there is no material to bolt to.
Added aluminum tabs to bolt to.
Where are the wheels supposed to go?
AMP Dynamic 3100 series connectors
Rudder wire connector.
Old 08-31-2024, 07:03 PM
  #724
Afterburners
I had to graft onto the rear mount as well for my Cheetah 140. Also when setting the recommended gap between the end of pipe and end of tail cone, the pre drilled rails with blind nuts doesn't come close to lining up with the engine/pipe assy. My fuse was cutout for the wheels though. It's all worth it as it flies great.
