Flight Hobby Top Stage 70
Old 04-09-2024, 08:44 AM
gil.s
gil.s's Avatar
Originally Posted by RICKSTUBBZ
is that 1/16 thick balsa for the "TURTLE DECK"
It is 2 mm balsa sheet. In inches it is 5/64”.
RICKSTUBBZ (04-10-2024)
Old 04-27-2024, 12:26 AM
gil.s
gil.s's Avatar
The fuselage sheets are now glued.
Some sending of the edges.
Glue the top cover of the fuselage.
The wood cover of the front
the main beam of the fuse bottom.
The tail bottom
Now on the fuselage. Will need some serious sanding.
Old 04-27-2024, 01:46 AM
gil.s
gil.s's Avatar
Preparing the tape in advance before glueing the bottom. This will save time when attaching the bottom sheets with the glue on.
Let it dry for a while.
Old 04-27-2024, 10:06 AM
flywilly
My Feedback: (121)
Coming along very nicely. I would precut that bottom tail block on a band saw to the approximate shape to reduce sanding, I’m lazy whenever possible.
Old 04-30-2024, 06:36 AM
gil.s
gil.s's Avatar
Thanks!
Yes, it makes sense.
Old 04-30-2024, 06:43 AM
  #31
gil.s
gil.s's Avatar
The fuselage is coming along nicely. I will now build the Canalyzer to assure proper fit to the fuselage and sanding. After that I will glue the cowl and build the canopy.
Old 04-30-2024, 06:44 AM
  #32
gil.s
gil.s's Avatar
So this is the Canalyzer and Jig.
The Jig is done, using CA.
Old 04-30-2024, 07:16 AM
  #33
RICKSTUBBZ
RICKSTUBBZ's Avatar
Because of your build I did hop over to the "Flight Hobby" website the other day to check out what all they offered.
I was in for sticker shock when I converted the cost of their kits. And I didn't even get to the shipping part.
None the less, it sure appears to be a well engineered airplane with all the right tools available to build it square...
What is the theory on using a Canalyzer?
Old 04-30-2024, 09:37 PM
  #34
gil.s
gil.s's Avatar
Thanks for following!
Yes, Japanese kits are not cheap, but I enjoy the process, and F3A 70 size planes are a rare find.
The Canalyzer streamlines the slipstream on the rudder and elevator, for better stability, and knife edge flying.
Old 05-01-2024, 02:26 AM
  #35
flywilly
My Feedback: (121)
Hey Rick,
Now is the time to buy a flight hobby kit. The yen to $ exchange rate is very favorable; today about a 37% discount. I buy from RC-Japan, they are great to deal with.
Flight Hobby kits are top quality as you can see in this build thread.
T-cans definitely increase rudder authority. Pattern moving to constant, generally slower, speed; more ‘gadgets’ are needed to provide aerodynamic assistance.
RICKSTUBBZ (05-01-2024)
Old 05-21-2024, 08:41 AM
  #36
gil.s
gil.s's Avatar
Canalyzer on the dedicated jig
glued with the cover sheets
now need to fit it to the fuselage
I glued the canalyzer front and pins, in place, using nylon to separate from the glue.
now it is ready for the fiberglass covering
the canalyzer ready and fit in the fuselage.
ram_z (05-26-2024)
Old 08-15-2024, 04:42 AM
  #37
gil.s
gil.s's Avatar
Old 08-15-2024, 04:44 AM
  #38
gil.s
gil.s's Avatar
It has been a while, as a summer is a flying season... But some progress on the direction stabilizer and the rudder.
Old 08-16-2024, 05:45 AM
  #39
flywilly
My Feedback: (121)
Looking good!
it is tough to get much building done during flying season!
gil.s (08-20-2024)
Old 08-20-2024, 09:02 AM
  #40
gil.s
gil.s's Avatar
aligning the motor
Old 08-20-2024, 09:15 AM
  #41
gil.s
gil.s's Avatar
Preparing the fuselage for the cowl.
checking that the cowl fits prior to glueing
Checking the fit of the canopy base as well
Okay, glueing in progress. I used black epoxy to do the magic.
