Boomerang Nano!!!
Boomerang Nano!!!
Old 05-15-2014, 11:17 AM
  #1551
Si_B
Si_B's Avatar
Well after a bit of searching I went for it. Didn't have to remove as much material as I thought and plenty of strength left in the bearer.
Thought I'd post a picture just in case anyone else went down the same route. Think I'm going to look at fitting the front retract before glueing the centre wing in place. I think the model is easier to handle at the moment.
Cheers,
Simon
ID:	1995560   Click image for larger version
Old 05-15-2014, 04:03 PM
  #1552
Art ARRO
Simon,
I removed about the same amount of material from the retract bearer with BVM 3/16" wire struts with no problems-after 4 seasons of heavy flight use. I agree on fitting the nose retract unit before gluing the center wing section to the fuselage. This step took quite a bit of thought to work out properly. I chose to fit a belly mount Spring Air nose retract to some "packers" to achieve a favorable stance for takeoffs and landings and keep the retract unit internal to the fuselage. Also raked the nose strut rearward for some castering action with a small bend above the nose wheel. You'll truly enjoy flying this Nano when finally complete.
Rgrds,
Art ARRO
Old 07-06-2014, 01:30 PM
  #1553
Si_B
Si_B's Avatar
She is all done.
Just done the calcs and she needs 40g of lead in the nose which is not too bad. Got everything mounted forwards, but with the electric retracts there are not cyclinders or valves up the front. Hopefully get the motors fired up and checked in the week ready for her maiden.
Cheers,
Simon
ID:	2012171   Click image for larger version
Old 08-13-2019, 03:05 AM
  #1554
extra 300
I know this is an old thread but does anyone know if a JP 005 LG set or a JP 010 LG set would fit in the Nano?
Thanks in advance,
Old 08-14-2019, 03:30 PM
  #1555
ltc
Thanks in advance,
another option might be a set of Prolinks from dreamworksrc
they sell a set designed for the Nano.
or perhaps contact a ripmax dealer and see if they know which JP retracts they are using in the new Nano release.
Old 08-16-2019, 02:04 AM
  #1556
extra 300
Itc,
Thank you for your suggestion, will contact Ripmax for advice. Prolinks are great (I have them on my XL) but I was rather looking for a more affordable option with trailing link legs.
Rgds
Old 08-18-2019, 06:24 AM
  #1557
ltc
JP is definitely the most affordable option
Dave at motorsandrotors in the UK would be my first stop for answers.
rc-Castle offshore has good prices and selections of JP retracts
Old 03-12-2020, 03:19 AM
  #1558
jmsjms
Talking Boomerang Nano
What is the red color code on the Boomerang Nano Royal Austrailian Airforce i have had a minor crash but need some new cower on the nose
Old 03-16-2020, 02:23 AM
  #1559
jmsjms
No one who knows
Old 04-12-2020, 10:02 AM
  #1560
timLQ
Does anyone have a Nano airframe only for sale?
Old 04-10-2021, 09:23 AM
  #1561
andrewjet
My Feedback: (16)
Well, I've been checking for 8 months or so for new replacement actuators for my Prolink retracts supporting the Nano however I have not had any luck. Dreamworks indicated that they are not able to get the actuators from the manufacturer so I've been calling approximately every couple of months or so, however, I finally took the plunge in ordering the new retract and struts package from JP Hobby. Man, I really was hoping not to be the guinea pig on this one however since they arrived so quickly I really thought I'd be flying this weekend however the tires are 65mm and the struts are too long and I would have to pull the wheel wells, repatch the holes, and recut the new areas for the wheel wells to accommodate the length. Has anyone else purchased these new units? I will try smaller wheels first since the new ones are 65mm and see where I am prior to surgery.
Old 06-07-2024, 08:45 PM
  #1562
raydar
Late to the party as per usual.
Picked up a Nano NIB and built it with modern equipment, ended up about 6kg dry. Could have been a couple hundred grams lighter but nose weight was still required even with a 472g turbine.
Xicoy X60 for power which seems to be the perfect engine for keeping the Nano light but sporty, JP electric gear, all HV servo's with midi Magregor on rudders and savox standard size on other surfaces.
Flys quite light even with the big stock tank filled which must be pushing this jet into the 7.5kg area wet.
Climbs a bit on power, my flap is neutral, CG feels if anything "sporty" on stock CG with plenty elevator authority. Added 3% down elevator curve with throttle starting 1/3 of throttle to compensate, may need a little more. Easy to fly.
Old 06-10-2024, 12:33 AM
  #1563
extra 300
Raydar,
Congrats for your Nano. i still have mine in the box and was planning for a JP landing gear to simplify things. Could you please advise which set you got and if it needed any modification to fit in the airframe.
Thanks in advance
Old 08-29-2024, 02:12 AM
  #1564
extra 300
any luck to have some info if someone still flying the Boomerang Nano and using a JP landing gear (which model specifically)...
Thanks in advance
Old 08-29-2024, 02:17 AM
  #1565
raydar
Angry
https://www.jphobby.eu/en/landing-ge...ontroller.html
These are the ones, they fit fine with no major modifications though are pull/pull on steering which requires a little thought to get the wires not to snag on operation.
They work well with my Nano which is prob about 16lbs loaded, the model has only had about two outings and 6 flights in total.
Wish I had flown more this season but wind and weather in UK this season has been relentless, still waiting for summer to arrive and it's near september
extra 300 (08-29-2024)
Old 08-29-2024, 03:00 AM
  #1566
extra 300
Raydar,
Thank you
Old 08-29-2024, 08:02 AM
  #1567
thedarkwraith
Picked up a Nano v1 airframe and in the process of fitting everything into it. Using the JP electric retracts and brakes (have them mounted already - nose was a pain!). Using a Swiwin 80b as the power source. I can't find the v1 manual or the manual for the Nano using the 2 silver rods on each wing to center it. Does anyone have a copy or can you tell me where to find it? Google keeps turning up the latest version.
In regards to CG, you measure this at the leading edge of the center wing part right where it's intersecting the fuse? What is the recommend CG range for the v1 and where is it measured from?
I'm assuming this is a v1 because of the 2 silver rods to center the wing on each side.
In regards to mounting the turbine do you mount it so output nozzle is flush with back or is their a specified distance from the back or ??
Old 09-03-2024, 01:10 AM
  #1568
extra 300
Can anyone please advise the difference between the Nano V1 and V2. i believe i have the V1 and would very much like to know if any major mods were made before starting the build.
Thanks in advance
