Go Back  RCU Forums > Electric Aircraft Universe > Electric Pattern Aircraft
BJ Craft Ultimate Biside Build
Electric Pattern Aircraft Discuss epowered pattern aircraft in this forum
Old 09-08-2024, 04:15 PM
helisax
Thanks very much for the information. Your flying field is something all clubs dream off!!. My Biside is building nicely thanks to your tips. Will let you know when it is done. Fun Gee
Old 09-20-2024, 04:06 PM
helisax
Hi when you say CG is 210 to 220 mm is it measured from the front of lower wing. The section that meets the fuselage? Thanks
Old 09-22-2024, 02:11 PM
shannah
Yes, from the section that meets the fuselage.
Old 09-22-2024, 10:42 PM
helisax
Thanks very much!
Old 10-03-2024, 09:14 AM
shannah
I was finally able to get back out to fly the Bi Side some more. After a couple weeks of travel and also closure of my flying site due to wild fires, I put in some more flights.
I installed the wing fences and tested them. I think they do help in making spin entries more consistent and in make spin exits a bit more crisp.
Overall, I am very happy with it. The Bi Side really excels at F25. I find it easier to fly the rolling corner elements, the snaps are very predictable, the rolling circle is pretty effortless, and the overall pace is very good.
I have a lot more fine tuning to do before it is contest ready but I am getting very close. I turned down my aileron throws, increased expo on Ail and Rud, and have been adjusting my throttle curves.
I found that increasing the shim height by 1mm on the top wing, rear bolt, seemed to help in windy conditions. It felt a bit more locked in when winds were at or above 15mph. I didn't notice any downside in the calm air so I will leave the shim set at 4mm total height. My CG is at 220mm back from the bottom wing front mounting bulkhead.
wattsup (10-03-2024)
