Skygate/CARF Viperjet
#726
Oops. I have seen that once before, yes factory has flipped the mount. It is possible to cut the servo opening wider to drop the servo. A 3/4” Razor saw blade will work. Servo position does need to match.
Dave
Dave
#728
Carf should be compensating you somehow with these mess ups IMO. Check your parts bags for the wing bolts. They are 5mm I believe. Mine were so short, they wouldn't even reach the fuselage blind nut. Had to run to Home Depot to pick some up as I didn't have any. 35mm I believe is what works.
#729
6mm. I have been involved with a lot of Vipers over the years and problems are rare.
For me I would quite like the wheel openings to be left. They can then be cut to suit the wheels/legs exactly. But, certainly this is not normal. As always, the Sales Rep you used is there to help. Although I know most of the US reps are at JetPower this weekend, they will still help.
#730
#731
My local CARF rep is awesome and he offered to fix things himself. I have a builder friend that is much better at making the cutouts than I am and he agreed to help making the holes in the fuselage.
I fixed the servo mount and moving on to getting the landing gear mounted. The flap servos needed a 1/8" (3mm) spacer to have the arm line up with the horns of the surface. So, I made a plywood plate to fill the opening and epoxied it in place. If anyone else needs to do this, here is a tip - drill the servo mounting holes before you glue the plywood in. Now left and right wings are slightly different and my OCD will have to deal with it.
The QC stickers put all over the model are a joke. It is like buying a four door car and it only having 3-doors when it is delivered to you
