Go Back  RCU Forums > RC Airplanes > Giant Scale Aircraft - General
TMMY Scale Composites 35% scale Cessna
Giant Scale Aircraft - General Discuss all other giant scale aircraft here.
Old 08-02-2024, 02:45 PM
  #2001
planenutzz
yes I have all of those antennas had them made for me.
Instrument panel I need to sort out as mine is the old 182Q style and model I am doing is 182T with G1000 panel.
Old 08-09-2024, 05:20 PM
  #2002
scottkieper
My Feedback: (10)
what size servo arms are you using on the flaps 1.25 or 1.5 , trying to set up flaps and do you use all the flaps in the down position [ raido settings ] in %
Old 08-09-2024, 05:33 PM
  #2003
planenutzz
I have not gotten that far but if your back through the thread I am sure others have posted what they have done.
I'd also research what settings the full size uses, given the size of this model that would be a good place to start.
Old 08-09-2024, 05:59 PM
  #2004
slevin1
My Feedback: (23)
I have a couple giant scale Cessnas and it’s usually about 10° for takeoff flaps and 30 to 40° for landing. Use those as a starting points. You’ll probably have to change the throws after your initial flights. Also it’s takes exactly 6 seconds for the full scale flap to travel from 0° to 40°.
Saul
Old 08-09-2024, 06:04 PM
  #2005
planenutzz
good info!
Old 08-11-2024, 09:52 AM
  #2006
scottkieper
My Feedback: (10)
Default Pics
just some pics
Super18 (08-11-2024)
Old 08-11-2024, 01:21 PM
  #2007
planenutzz
your dash is a lot better than the one I got. Original owner must have told them to just supply an old steam gauge dash.
I will make a new one.
Mine is deferred for the time being, still waiting on the brakes and associated hub machining.
Old 08-11-2024, 01:22 PM
  #2008
planenutzz
I will be making an additional 2, perhaps 4 tail mounting points.
Old 08-12-2024, 03:30 AM
  #2009
scottkieper
My Feedback: (10)
what are you making,? im look for some glide scopes. also looking for all the scale [decal ] markings who makes them . what size batterys are you using????
Old 08-15-2024, 01:05 PM
  #2010
planenutzz
additional 2 tail mounting points. No idea on decals, I have not had any luck with those as yet.
DME and other antennas etc try iflytaillies or Jiri Piri
Old 08-15-2024, 04:48 PM
  #2011
scottkieper
My Feedback: (10)
Time to order da150 what size prop and what make that you are using.. if i can ask...
Old 08-16-2024, 01:21 PM
  #2012
planenutzz
interesting approach to getting help. answers are in the posts earlier. good luck
Old 08-16-2024, 03:54 PM
  #2013
scottkieper
My Feedback: (10)
Wow
Old 08-16-2024, 04:05 PM
  #2014
planenutzz
reap what you sow.
Read the posts, there are answers.
Old 08-29-2024, 02:41 PM
  #2015
scottkieper
My Feedback: (10)
Default Tmmy pics
new 150L
The following 2 users liked this post by scottkieper:
planenutzz (08-29-2024), Super18 (08-30-2024)
Old Today, 12:15 PM
  #2016
scottkieper
My Feedback: (10)
Inside all done painted ,engine mounted waiting for mufflers and prop. 2 more weeks for that stuff.looking good.
Old Today, 01:24 PM
  #2017
planenutzz
came out nice, well done. Instrument panel does look good. Mine is on hold till I get the brakes sorted, friend is doing machining for me.
I need to get all the G1000 surrounds etc for mine, was going to get somebody to program up some functional ones but think it will be too expensive to do.
One thing to watch is with the seats, they are quite flimsy at the outside of the bend and will crack. I am going to put a layer of either carbon fiber or 6oz cloth to that area.
What size fuel tank did you put in?
cheers
P
Old Today, 02:38 PM
  #2018
scottkieper
My Feedback: (10)
I put in the stock tank 300 cc see the mounting I did right behind the dash and fill thru the wing
