Pica Duellist 2/40
Pica Duellist 2/40
I was trying to get the Pica Duellist 2/40 kit for over 3 years. Sellers on ebay from the USA refusing to consider international shipping meant that the (very) few that get offered for sale were not available to me in Australia. When winning a bid on ebay with a seller offering international shipping, that US seller cancelled the deal and refunded the money... Finally, a kit became available on ebay in the UK and I managed to purchase it in April 2023.
Other kit building deferred the start (such as the Lanier RC Giant Stinger), but finally last month I started the build.
I will post photos and some comments when time permits, the actual progress is always slightly beyond what you see here.
Below are photos of the kit as arrived and its content:
Cheers,
Eran
Cheers,
Eran
With the usual set of plans, there were also couple of transparencies for the fuselage set of plans.
Construction starts with the wing, specifically with ribs W2, W3 and W4 which will support the landing gear and therefore have a plywood doubller. I will be building the fixed gear option.
Cheers,
Eran
Cheers,
Eran
Carl - I don't have engines lined up yet. I wanted to fit two O.S. 40 FSR engines for nostalgic reasons, but they are getting hard to find (N.I.B) and expensive. It is likely to be two O.S. 46AX's. I had to quickly secure the two fuel tanks, as the design was around the Sullivan 8 oz (#439) with the sloped front (with Sullivan being out of business and its future uncertain).
Some progress on the wing construction
Cheers,
Eran
Cheers,
Eran
Talked with a Sullivan rep two weeks ago at a scale contest, he indicated the R/C line will be back up and running soon. I hope he is right. The wheels will not be part of the reopened business.
Tony - I truly hope that this information is correct, however, I will believe it when I see it. I use their products often (and for over 35 years) and find them to be of good quality.
Cheers,
Eran
Cheers,
Eran
Continuing with the right wing panel, TE, main and secondary spars installed as well as gussets. I forgot to mention in the previous post that the plywood mount for the throttle bellcrank was not installed when I glued the ribs in place (W-11).
Cheers,
Eran
Cheers,
Eran
Gluing the center section servo rails that I am not planning on using as I think they add some strength to the center of the wing. With the right wing done, I started preparation for the left wing including the 3.5" dihedral support.
I also drilled a hole in the ribs W2 to W6 for servo wiring (and did the same in situ for the right wing).
Cheers,
Eran
Cheers,
Eran
LuvBipes - Retirement, this is something to look forward to. I hope that this build may be helpful in some way (even if by motivating to start the Duellist build : ) ).
Cheers,
Eran
Cheers,
Eran
