Fokker D VII Resheme
Wow, well it’s been a while! I thought i get back into it with a Hanger 9 60cc 1/4 scale Fokker D VII.
I’ve removed most of the covering and am awaiting my order of Oratex in antique color. Will repaint but haven’t decided on a scheme. I’m leaning toward an early “brushed” style but not sure…
Upgraded parts from Scale RC Engines include: new cockpit kit, new guns and dummy motor
Avian 8075-230kv brushless outrunner
Avian 120 amp smart esc(with fan)
2 Spektrum 6s 30c 7000mah LiPo batteries(12 cell)
Spektrum A6380’s for Servos
NX8+20 channel DSMX
AR8360T receiver with safe and telemetry
Best Pilots Lothar
MRRC sound
24x10 Xoar Scimitar WWI series prop
wish me luck!
NX8+20 channel DSMX
Best Pilots Lothar
MRRC sound
wish me luck!
Throwing around some ideas for simulated rib stitching, this is a mock up using painters tape and some cotton string(slightly to large atm)…I’ll use aluminum tape for final run cut into 1/8th in strips as long as needed. This will be applied before the Oratex.
I am also working a fix for the lack of the scalloped trailing edges for both the upper and lower wing surfaces…
stay tuned!
Casey
stay tuned!
Casey
