Topflite red box ZERO kit, starting build
Old 06-28-2006, 03:11 PM
reaaz
Default Topflite red box ZERO kit, starting build
I got a unbuilt ZERO Topflite redbox kit from a friend about 3yrs ago. Now i'm looking to start building it. Looks like a nice build but will need some mods to firewall as it has the wood engine mounting. Everything in the kit is still in good shape, which is cool for something made 24yrs ago. plan to finish in paint.
One thing i was wondering about the zero was that in some the gun on the fuse have the nozzles pass through the front top portion of the cowl. This is one scale feature i want to get in the ABS cowl but would mean cutting out eliptical portions in it & filling in the opening to look like a trough. Can 25yr brittle ABS handle that?
Old 06-28-2006, 11:00 PM
tailskid
My Feedback: (34)
tailskid's Avatar
Default RE: Topflite red box ZERO kit, starting build
Don't see why not....but I would recommend you make a 'template' of each part and a copy of the plans....like you said, it was made 24 years ago and things have changed
Old 06-28-2006, 11:51 PM
warbirdmustang
My Feedback: (21)
Good idea about making copies of the kit, but if it has been kept out of sunlight, and taken care of, it should build as good now as it would have then. I have used the wood engine mounting beams, and there is absolutely nothing wrong with them provided your engine will fit them. The problem I have found with the older kits and that setup is that the firewall location will let the engine stick too far forward out of the cowling. I have not built this kit before, so it may not be the case with the Zero. Please post pictures of your progress!
Bryan
Old 10-09-2024, 06:20 PM
mrmopar
Default rebuilding a zero
i was wondering what the wingspan is on her trying to figure out what i actually have thanks for any help
Old Today, 07:02 AM
scale only 4 me
My Feedback: (158)
scale only 4 me's Avatar
I'd give Fiberglass Specialties a call and see if the gun slots are molded into the one they make
60-61" span if I remember right
