Tomahawk Futura Build Thread
Old 05-20-2021, 08:06 AM
  #276
Desert Fox 1
Cheers!
Desert Fox 1
Old 10-28-2021, 11:00 AM
  #277
crhammond
My Feedback: (21)
I flew mine a fair bit this past summer. I have the V2 and although it flies very nicely it is HEAVY and sluggish doing pattern maneuvers. The wings, tail and rudder all have a lot of heft to them. I am on the fence weather to spend some money and time to lighten it up or fly it one more season and get something else. The main issue with the weight is that heavy feel in the sticks... As a result of the heft it fly's much better fast which is not really what I wanted. I was hoping for that nice slow constant speed but precise flying the V1 demonstrated. The V1's were much, much lighter (like over 2kg lighter.) It still lands okay - but I also had to upgrade from my Behotec C50's to Electron ER50's as the C50's were really borderline at my 21.5kg dry weight (8mm pins could not take cross wind landings for example.)
In comparison - my friend has a Rebel Max which is substantially larger and is 2kg lighter dry weight! The flying surfaces in particular are feather weight in comparison.
Old 10-28-2021, 11:06 AM
  #278
DUCMOZ
Hi, mine is one of the kits (not arf or painted) and i built and painted it and it is at 37.5 lb with fuel in UAT. how much yours weigh?
Behzad
Old 12-20-2021, 04:06 PM
  #279
PILOTMD11
My Feedback: (19)
PILOTMD11's Avatar
On the 2.5m Futura, does anyone know how much elevator trim needed with takeoff and landing flaps?
Old 12-20-2021, 04:12 PM
  #280
DUCMOZ
Hi, I don't have any with Takeoff flap but about 3mm for landing flap. Of course you know that the CG location and the set-up of the plane could play some role on the amount.
Behzad
Old 05-09-2022, 10:59 AM
  #281
haisanjafri
haisanjafri's Avatar
Hi,
Acquired a Futura 2.5m V1 recently. Its having a white and red color scheme which isn't very eye catching. Planning to remove the paint with wet 600 grit emery paper. And then repaint the model Any tips from experts? I wish to accomplish this by adding minimum or none extra weight. Also planning to swap pneumatic gears with electron retracts combo.
Old 05-11-2022, 08:15 AM
  #282
mikes68charger
My Feedback: (34)
Originally Posted by haisanjafri
Hi,
I have stripped several jet with the Orange Paint stripper from Lowes. I don't leave it on very long and use a plastic scraper, make sure you don't add any deep scratches. But The paint on these jets is very thin, I would wet sand the whole jet with 400 wet on any overlapping paint IE invasion's stripes, then wet sand the whole jet with 600.
The next step depends on your paint you will use, if you are going to paint yellow, you really need to put a white primmer down fist as yellow dose not cover very well and takes a lot of layers to look right.
I have use several different paint systems on my jets, from KlassCoat Epoxy paint, single stage automotive paint (already has clear in it), to base / clear.
I love KlassCoat as it very strong and chip and scratch resistance, but is also a single stage so comes out very shinny, but Im sure its a tad heavier than Base Clear but don't need a primer coat.
I use Base / Clear on most of my jets, I only use the base with no clear on war birds jets for nice semi/flat paint, and base clear on most jets as you can paint over and seal any decals nicely.
Single stage automotive paint is very easy to paint and looks nice not as shinny as Base Clear.
So if you really want to try to strip, do one bottom of elevator and weight it vs other elevator sanded with 600g
I have one of these 2.5m I hope to fly soon, Good luck.
Old 07-02-2022, 02:35 PM
  #283
Desert Fox 1
Cheers!
Desert Fox 1
Old 07-02-2022, 11:39 PM
  #284
zx6rg2
Default 2.5 futura
Hi could anyone tell me the best settings c of g ect for the 2.5m as I am about to get mine finished and test fly thank you
Old 07-03-2022, 07:50 AM
  #285
DUCMOZ
Hi, it is the back side of the wing tube.
Old 07-03-2022, 08:51 AM
  #286
zx6rg2
Default 2.5
Hi thank you for the info
Old 07-09-2022, 02:36 PM
  #287
Desert Fox 1
Cheers!
Desert Fox
Old 07-22-2022, 06:54 PM
  #288
Desert Fox 1
Cheers!
Desert Fox 1
Old 07-23-2022, 05:06 PM
  #289
Desert Fox 1
Cheers!
Desert Fox 1
David J Ruskin (07-24-2022)
Old Today, 02:04 PM
  #290
Desert Fox 1
Cheers!
Desert Fox 1
