Powerbox Core radio and set up thread.
#1978
Hi Angus,
Just out of curiosity did you press on the the update for the operating system or the application when you started the update process...?
If you clicked on updating the application, you just need to go back and update the operating system.
The whole update process should work ok just by updating the operating system... no need to click on any other update buttons.
Also - just double check your audio settings in the audio menu in case your volume is down too low and you simply are unable to hear the sounds.
The following 2 users liked this post by BarracudaHockey:
Len (10-14-2024),
Springbok Flyer (10-10-2024)
#1982
Hi All, I am trying to have the trim to beep when i change the trim but no matter what i do on this model, it does not do it. have you guys experienced this ? Here is my screen. I also have the beep in functions set up.
Behzad
Behzad
#1983
You are looking in the wrong spot...
For the Trim, audio/vibe controls are setup within the Trim Menu found in the main Functions screen.
Once in the Trim menu the audio and vibration options can be found here in the 'Signal' type selection box.
If you have set it up correctly as per above... are you getting other sounds through the speaker...?
#1984
Hi Costas, thank you . I am in correct spots and have correct set-up. The only time I receive any feedback is that if I have it on Vibration and Beep. Then when trim in center, I get vibration and still no beep. But don’t get any sound or vibration once I move the trim. Now that you mentioned sounds, I noticed that I am not getting any sounds from the timer although it is set up for beeps. The radio does not have much use on it. Thanks again.
Behzad
Behzad
#1986
Hi Andy, thank you soooo much. I had not updated the OS. As soon as I updated it, it worked. I have the Transceiver 1.46 and Stickcontroler at 1.5. Are these correct?
thanks again.
Behzad
thanks again.
Behzad
#1987
You don't fool with those, they are automatic. Application and OS are the only ones that you should fool with (and the receivers of course)
Now that you're up to date go into the receiver update menu like you're going to update a receiver and use the new button to download the latest firmware available for all the receivers.
And you're welcome.
And you're welcome.
#1988
My Feedback: (99)
And you're welcome.
And you're welcome.
