Stuff needed to build the SS
UT
I just did a search on this and didnt turn up anything so, what do i need to build the Savage SS. I'm talking like glues, locktite, tools and stuff like that.
The Doc.
The Doc.
TN
RE: Stuff needed to build the SS
radio equipment such as servos, reciever, and transmitter (controller). and i suggest some locktight also. oh stuff to build i got ya. ok, you need the locktight, no glue. and you will need a phillips screw driver, some allen wrenchs, i have no clue what sizes. you will need some patiences also.
The kit should come with the necessary tools you'll need. I don't have a Savage SS, but I have an on-road RS4 SS and it came with a little tube of loctite, two sizes of allen keys, a turnuckle wrench, wheel nut/pivot ball wrench, shock oil and some grease for the diffs and axles. All you should need to put it together is some basic screw drivers and some thin CA glue for the tires.
