spur gear bad already??
RE: spur gear bad already??
Tighten it all the way down. If you go to www.savage-central.com and read up on what people are doing with thier bigger engines, you will see that guys using Wasp's and Picco's are doing this. With the Sirio I think it is a V.good idea.
NJ
i run the picco 26 which makes pretty strong power, running the stock 52 or 49 tooth gear and tighten them all the way down and then off 1/4 turn, and have had no problems. also make sure you are using a friction pad on the spur. one more thing..... your slipper spring may be weak, consider replacing it with that big engineif you have any amount of run time on it. backing it off a 1/4 turn is important though for the harder landings on power to keep some of the stress off you transmission and related components.
vizaracer, you posted it a while back agao that you got a STEEL spur gear from RR,
Is it the Steel spur gear that u melt??????
TN
nope. it was the plastic. this is an old post. i have the RR set now and it works perfectly fine. no more melting!
this post goes back to 3/20
i will receive my steel spur gear tomorrow
did you tight all the way down?
is there a pad behind the spur gear like the one in plastic?
