Want LiPo
VA
RE: Want LiPo
Try hobby-lobby.com or helihobby.com . They've got really nice batteries and chargers for a good price at helihobby but take a look at hobby-lobby as well. Good luck!!
NY
RE: Want LiPo
I also am looking for 1 or 2 li-po's for my areohawk and a charger. Looked at ebay, but as a newby it's hard to tell the crap from the gold ya know? Do you have any suggestions on which ones and why?
RE: Want LiPo
RE: Want LiPo
once you try one you will never go back
See the AMA warning here: [link=http://www.modelaircraft.org/templates/ama/safetycom.asp]AMA LiPo Warning[/link]
RE: Want LiPo
I am at confusion with Lipos 2s, and 3s packs. I hear a lot of people on the forums saying that 3's will burn out my electronics but i want to go 3's incase i get a CP chopper like a shogun or sometin. I currently own a FP Hummingboard with speerates, century piezo gyro, and century mixer board with a DD tail motor. Would i be safe going with 3's instead of 2's? Thanks guys.
RE: Want LiPo
NY
RE: Want LiPo
What does it take exactly to run a 3c lipo in a micro? New electronics? motors? What charger do you guys recomend that will charge more than just lipos?
RE: Want LiPo
I use the Hobbico's Quick Field Charger MkII, it works great. The good thing about this charger is you can't screw up when charging a Lipo battery, the charger will not charge any faster then 1 amp, so you don't have to worry abut your battery exploding.
RE: Want LiPo
ORIGINAL: Charlie
It runs off a 12 volt battery.
Does Hobbico's Quick Field Charger MkII use AC power or do you need a car battery?
RE: Want LiPo
They will, you just need a 12v transformer with a high enough amps output if the charger has a built in inverter. If not then you need one with high enough voltage to compensate, I use my cordless drill batteries which is more convenient than a car battery.
RE: Want LiPo
I went to walmart and bought a atv battery...a lawn mower battery will work too. I also use the hobbico mkII pro series charger. I like it cause I can charge two packs at once. Here is a story about the 12 volt supply.
I bought one of those adapters that you would find at wallmart that converts your wall plug into a cig. lighter jack. It is isued to use your automotive neon lights in doors. I bought this and ran a small charger for my stock packs. It worked fine. I then bought the hobbico charger. It doesnt have a cig lighter plug on it so I took and bought a cig. lighter plug with the wires off the other end. I put some spade clips on the end so I could clamp my alligator clips that came with my charger to the cig. lighter plug. I then plug it into the adapter and it worked fine. Untill I tried charge 2 packs at once. The max mah output was 1000 and I didnt even read that till after. I was charging 2 packs at 1000mah each....needless to say I fried the adapter. It cracked in half and smelt really bad.
So being upset and wanting a resolve. I went back to walmart and bought a atv battery for $19.99 and it works great. I have it on my desk becouse it is small enough and if I go over to a friends I can bring it with me so I can charge in the house. For 19.99 it is a great deal.
I thought my hobbico charger was bad for a while. I only got about 5 minutes of flight on my 2100mah pack. I just relized my motor was pinching the gear a bit and that would probley be my problem. I am going to test it out tonight.
How long does your charge time take with the hobbico charger? mine takes 45 minutes each pack.
RE: Want LiPo
ORIGINAL: sauske
I want a cheap but good charger for 2s LiPo. where can i find one?
The Apache 1215 is an excellent, safe low cost li-poly charger. I've used one now for the
last six months. I also bought one of those 12 dollar safety circuits from FMA (double protection is always good)
http://www.lightflightrc.com/HTML/pr...pache-1215.htm
