rebild time
RE: rebild time
idk *** u talkin about wuts the piece look like and u can get parts at www.rcuniverse.com
RE: rebild time
Why don't you just buy a new S-25? It will cost you about the same as a rebuild kit and it will be a brand new engine. Try Ebay. I see some going for $75-$100. The piece you are referring to is called a con rod.
NJ
RE: rebild time
hmmmmmmmmmmm whats going
get a new motor saver
engine maybe
tires rims
steering bell cranks
clutch set up clutch shoes
fuel tank if damaged
servos
radio
chassis to thicker
dual disk brakes
cooling head
pipe
shocks
alot of things u can put on a savage
engine maybe
tires rims
servos
radio
chassis to thicker
dual disk brakes
cooling head
pipe
shocks
RE: rebild time
ORIGINAL: kamil
engine maybe
tires rims
servos
radio
chassis to thicker
dual disk brakes
cooling head
pipe
shocks
engine maybe
tires rims
servos
radio
chassis to thicker
dual disk brakes
cooling head
pipe
shocks
