ATTN: SEAN EVANS
ATTN: SEAN EVANS
I have the older version of the yellow aircraft F16C, already built with ducted fan,
What would be the best turbine suited for this airframe and what structual means shoud i take
(wing spars, gear ect this airframe currently has the spring air , ( ibelive 302's not sure)
it was the reconmendation from yellow for an alternative to the scale. Plus is the intake important with turbine as it is with ducted fan?
thanks in advance: Chuck
RE: ATTN: SEAN EVANS
Chuck,
Did you build the kit yourself? How old is the plane? Actually, I've got a million questions for you, so why don't you give me a call at one of the two numbers below. If you don't have a good long-distance plan, just call and I'll call you right back.
Cheers,
Cheers,
sean i called at both numbers,,
i'll be up all night so just pm me and i'll log off so you can call or i can call you, doesnt matter how late..
Chuck
Chuck
