Steering Servo Question
OR
Just finished dialing my new Savage 25, and was She shifting sweeeeet! Problem is, after 8 tanks of fuel, my steering servo sounds like an extraterestrial on rewind! I think I've stripped the gears? Whenever I turn on the receiver, the servo seems to be looking for something?------Maybee ET? Help!!
RE: Steering Servo Question
stripped (middle gear) of Savage stock steering servo (HPI SF 2)... Replaced it with a Thunder Tiger S-188 new servo I had laying around... It didn't hold up 1 day of bashing... stripped it too... Finally gave up and installed HPI SF-3 metal gear servo... night & day difference!!
By the way I had my doubts about the servo saver... tesed it... and worked well.
Just my 2 cents...
Just my 2 cents...
OR
Thanks for the quick reply desertbuzz! What is a HPI SF-3 metal gear servo? Pardon my ignorance, but a beautiful day of bashing just came to an end!
Airtronics 94358 is the best!!
Here is a chart that tells about each diff servo
http://www.fatlion.com/sailplanes/servochart.html
OK
ORIGINAL: cyeutter
Thanks for the chart..very informative!!! Have been looking for this for a long time now.
My pleasure Hacksaw...
The SF3 is the servo that HPI offer as an option with metal gears... It's rated at 6.5kg/cm of torque.... HPI Part # 80561
A suggestion... instead of investing in a new servo... just buy the metal gears conversion pack to upgrade your stripped plastic gears to metal (HPI part # 80587).... (Your stock steering servo is the SF-2).
OR
Okay!----Okay!-----Just an update to my post. Thanks to you all for your suggestions! Put in a HiTec HS 645 today, w/ a Kimbrough servo saver #124. I'm A' Bashin' Agin! One more step in the learnin' curve
