Do you wrap your ignition lead?
Old 01-03-2005, 11:25 PM
Ken Bryant
My Feedback: (10)
Ken Bryant's Avatar
Default Do you wrap your ignition lead?
I just got my DA 50 and flew it only 7 times now I discovered that the ignition lead has the outer sheilding fraying due to chaffing.
DO you guys wrap your ignition lead in Spiral wrap or protect it any other way?
I am stuck routing mine only one way but I don't want it to fray anymore.
Old 01-04-2005, 12:02 AM
Tired Old Man
Default RE: Do you wrap your ignition lead?
If it looks like the plug wire has a possibility of rubbing on something, I'll go ahead and wrap it with thin foam and electrical tape if it can't be re-routed. Make sure that the lead doesn't come in contact with the cut edges of a fiberglass cowl. That will end any plug wire pretty darn quick.
DO NOT use any kind of metal wrap on the lead! Should it start banging against something else metal you will have more interference than you will know what to do with.
Old 01-04-2005, 12:10 AM
Dan767
My Feedback: (19)
Dan767's Avatar
I wrap mine with spiral wrap. Radio Shack and the home improvement stores carry it. I prefer clear, but either is fine.
Old 01-04-2005, 02:13 AM
GoeKeli
My Feedback: (18)
GoeKeli's Avatar
I use nylon spiral wrap and then the black plastic wire protecting split tubing. That tender plug wire is all that is between me and a big loss,, I take real good care of it!~)
JOe
Old 01-04-2005, 05:12 AM
mikenlapaz
I took some thick walled vinyl tubing and spiral cut it with #11 blade; made a nice thick protection cover. First run on a CH Ign and chafed just being in contact with some butter smooth VHMW.
Old 01-04-2005, 09:04 AM
Ben Diss
My Feedback: (23)
Another trick is to tie wrap the lead to the part that it is going to bang against. By holding it firmly in place it won't be able to abraid the wire insulation.
-Ben
Old 01-04-2005, 12:37 PM
sillyness
My Feedback: (25)
sillyness's Avatar
I use spiral wrap, split tubing and I also line the edge of the fiberglass cowl with some vinyl trimming/combing I got at my hobby shop.
Old 01-04-2005, 04:57 PM
min
Brian F**t, how about that foamy material that they spry to isolate window frames with the walls.
It's light wieght and good isolater.
any ideas?
Old 01-05-2005, 06:41 PM
pe reivers
I tie-wrap it to the fuse using a local foam pack, or anywhere else it may rub. Anything to keep that HT lead fron Harm.
A spiral wrap should be fine, if it is tight. Such a wrap also adds mass, which may induce extra vibratory loads on the lead.
The choice seems to be yours. Just as long as you take care and keep the lead secured.
Old 01-05-2005, 11:52 PM
Ken Bryant
My Feedback: (10)
Ken Bryant's Avatar
Thanks to everyone who responded. I only wish I knew this stuff prior to my lead getting dorked up. I have sent the ignition module back to DA to get the braiding replaced. After I get it back I will heed all the advice I have recieved here. Thanks again!
Old 01-06-2005, 03:01 AM
Antique
Antique's Avatar
It will be interesting...The cable and shielding are molded and crimped into the ignition, not readily replaceable....
Old 01-06-2005, 11:07 AM
Albatross
My Feedback: (7)
This is how I shield the ignition cable, notice the silicon tubing wrapping the cable only on sections were is more likely to suffer damage mainly due to the proximity of cowl edges.
By the way I did not think about the spiral wrap, I think is a good idea too, I will try next time
Old 01-06-2005, 02:34 PM
Skyking-RCU
Albatross,
What can you tell me about the swap in Waukesha this weekend? Is it worth making the 1.5 hour drive for?
Terry
Old 01-07-2005, 02:23 AM
Albatross
My Feedback: (7)
SkyKing-RCU
Does not have the glamour of a big city RC event; however I think is worth to try. More details in your e-mail
