MAIDENED MY SEAGULL 540 TODAY!
WA
RE: MAIDENED MY SEAGULL 540 TODAY!
Thanks Nedyob. I will take a look at adding some hardwood blocks to the wing mount cross braces. Also, I think I read somewhere earlier that you added struts to the rear stabilizer and rudder but then took them off. Have you heard of others who have them on this plane, and/or possibly any others who have had failure due to not having them? It might me a weight issue to.
WA
Thanks for your feed back P-40LUVR. I tend to agree with you. The landing gear looks beefy to me even if it is cheap metal. I think I just read somewhere that some guys were replacing them with aftermarket LG to reduce the risk of them bending. I think you're right-if I bend these LG somethings wrong.
My Feedback: (67)
IA
Glad to hekpZMCOUGAR,
Yes, I did have flying wires on the tail on my first Sdge 540, but took them off because they made the Edge very tail heavy. I did put triagle stock on where the horizontal stab meets the fuse. This gave it the reinforcement it needed. I have never had the rear stab break apart on me as long as I,ve owned the Edge 540.
After the demise of my first Edge 540, (I take all the blame for the crash, and cant blame the plane) The landing gear did bend slightly,and no damage to the landing gear block.
Any way, on my second Edge 540. I did reinforce the fuse. sides with pop cycle sticks. This would be in the area of the wing saddle.
This is were the most damage was caused after the crash of the first Edge 540.
NEDYOB
NEDYOB
My Feedback: (67)
IA
I used 1/2 inch. I got it cut to size and then covered them with matching red monocoat and then glued them on. Can't even see them there unless your right up close.
NEDYOB
NEDYOB
#31
WA
Thanks Nedyob. Sorry to keep asking so many questions... but did you reinforce just the top of the stabilizer or did you put the triangle stock on the bottom as well?
#32
My Feedback: (67)
IA
Top & Bottom. Later after the plane was finished I had someone else checked the plane & everything over before its madien flight. and they said the stab was sturdy enough w/o out the triangle stock. But after being told the Endge 540 was known to have a weak Stab, we checking it out during the maiden flight and did some wild snaps, and nothing came loose or broke. So the triangle stock was added insurence.
NEDYOB
NEDYOB
#33
Hey I have an edge. I had a Thunder Tiger .91 in it but it did not seem to be producing enough power. Now am am putting a Thunder Tiger 2 stroke pro 120. any ideas on if this will be to much power.
