idle????
NE
idle????
What would cause the wheels to turn pretty fast at idle? I have had the wheels turn slightly at idle and I just adjust the idle needle and it goes away but I cranked my savage today and they were turning hard. I have adjusted the idle screw and have not gotten any better results. Could it be high or low speed needle settings? I know the clutch is engaging and spinning the wheels but I can't figure out why. The mesh is right. It definitely has something to do with needle settings right? Thanks for any help.
RE: idle????
Could be your clutch springs as they do get weaker with time and heat..........maybe have a look to see what condition there in.
JMO
Good Luck
JMO
Good Luck
NE
RE: idle????
I looked at the clutch springs and they are so so. They are going to have to be replaced shortly. After some tuning I have it where the only time the wheels turn is if I lift the truck off the ground. I have never tuned a truck in this cold of weather so I am lost. Any ideas? Does it sound like I am rich or lean on the LSN? thanks.
RE: idle????
ORIGINAL: blah-blah
What is it like from a standing start ?? performance wise ??
RE: idle????
I've had the same problem. You need to richen up your low speed.
But be careful. Don't richen it to the point where it idles down by turning it. Do it in 1/8 increments, run it and bring it back. You don't want to make it so rich that it loads up with fuel either, or it will die if it sits more than a few seconds.
RC Nitro has a great article on tuning. http://rcnitro.com/rn/articles/ht_tunengine_01.asp
